Will this tire size trigger the VDC?
Old Oct 11, 2005 | 09:20 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default Will this tire size trigger the VDC?
I saw a good deal on the tire sizes 275 30 19 and 245 35 19. I know the wheel in the back is supposed to be within certain specs for the vdc to not always kick in. Do these sizes meet the requirements?
Old Oct 11, 2005 | 09:33 PM
Nexx's Avatar
Nexx
its a toss up, its not recommended. some people have had problems and some have not. Why not go with a 265/30/19 in the front?
Old Oct 11, 2005 | 10:46 PM
DELETE
Old Oct 11, 2005 | 10:50 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Hmmm, how will that affect the looks of the tires?
Old Oct 11, 2005 | 10:57 PM
You have a problem: the front tires are taller than the rear. This may confuse VDC, and not operate properly.
Old Oct 11, 2005 | 10:59 PM
Nexx's Avatar
Nexx
it would look less odd then your proposed 245/35, 275/30 and it would be a more balanced setup as well. the sidewall would be slightly shorter in the front with the 265/30 setup which is just right and should not confuse your VDC. you can get a 265/30/19 and 275/30/19 setup made by General Tire from Tirerack for about $620.00 shipped to your door. Not the best performing tire but it they are suppose to have long tread life.
Old Oct 11, 2005 | 11:04 PM
Badmonkey's Avatar
Badmonkey
Go with the tried and true, 275/35 and 245/35 setup.
Old Oct 12, 2005 | 04:43 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Thanks everyone, I went with the Toyo T1-R 245/35/19 & 275/35/19. So far, they are GREAT tires. Excellent grip on turns. I just hope they last longer than the Bridgestones.
Old Oct 13, 2005 | 04:50 PM
Nexx's Avatar
Nexx
oh no, you didnt buy the toyos for longevity did you? Better baby those, they are really good for traction but man they do wear quickly.
kyin
Oct 15, 2015 05:54 AM
