Nitto NT 555 245 (F) & 275 (R) on stock 18's
Old Dec 27, 2002 | 02:35 PM
SHO-TIME's Avatar
SHO-TIME
Talking Nitto NT 555 245 (F) & 275 (R) on stock 18's
I got a nail stuck in my stock tire and decided that it's a good time to replace all four tires. I went with:
NITTO NT 555 Extreme Performance
Front: 245/40ZR-18
Rear: 275/40ZR-18
These tires fit quite nicely. Here are some pix that I took at the shop.
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-rearview-with-new-tires.jpg
Old Dec 27, 2002 | 02:36 PM
SHO-TIME's Avatar
SHO-TIME
Side view
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-sideview-with-new-tires.jpg
Old Dec 27, 2002 | 02:38 PM
SHO-TIME's Avatar
SHO-TIME
Front
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-tire_front-after.jpg
Old Dec 27, 2002 | 02:39 PM
SHO-TIME's Avatar
SHO-TIME
Rear
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-tire_rear-after_angle.jpg
Old Dec 27, 2002 | 02:40 PM
SHO-TIME's Avatar
SHO-TIME
For those of you who haven't see the tire pressure censor... here it is.
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-tire-pressure-censor.jpg
Old Dec 27, 2002 | 02:42 PM
SHO-TIME's Avatar
SHO-TIME
And for comparison.... stock front
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-tire_front-before.jpg
Old Dec 27, 2002 | 02:43 PM
SHO-TIME's Avatar
SHO-TIME
and stock rear
Attached Thumbnails Nitto NT 555 245 (F) & 275 (R) on stock 18's-tire_rear-before.jpg
Old Dec 27, 2002 | 04:31 PM
rodH's Avatar
rodH
WAIT, i thought that Luke@tirerack said that the largest tire that can fit on a 8" wheel is a 245??
Old Dec 27, 2002 | 05:00 PM
Zmeflyby's Avatar
Zmeflyby
the more grip the better
now go to the drag strip and run ur car!
i wanna see some times w/o the stock crappie tires
Old Dec 27, 2002 | 06:02 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default Thanks for the info!
These will be the size of tires I will replace the factory's with...
Probably with Kumho MX's...
How much were the Nitto 555's?
Old Dec 27, 2002 | 06:10 PM
wadd3456's Avatar
wadd3456
JESUS H CHRIST. I knew it could be done. Everyone was telling me dont do it dont do it. Yet i kept hearing stories of people putting 275's on . Thats IT! Im buying those axis mod's and throwing a 275 on that bishums
Old Dec 27, 2002 | 06:42 PM
D'oh's Avatar
D'oh
Did you happen to find out if the stock 18's were the same width front and rear? In the owners manual it says the wheels are 18 x 8 all around, while in the sticky at the top of the page it says 18 x 7.5 in front and 18 x 8 in back. I've measured my 18's, and they seem to be the same size, but I'm not sure how accurate my measurements were.
Do you have any clarification?
Thanks,
D'oh!
Old Dec 27, 2002 | 07:26 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I thought this was settled long time ago...
it's 18x8 all around..
Old Dec 27, 2002 | 11:39 PM
SHO-TIME's Avatar
SHO-TIME
I've been driving around in my new tires and they are very smooth. There feels like less vibration from the road due to additional rubber becoming an added cushion. No rubbing at all under hard driving and hard cornering. And they hug the road a lot better than the stock Bridgestones.... allowing me to take the curves at higher speed than before.
Apexi 350z:
I didn't know that was even an issue. I guess I don't hang around on this board enough to know that... but visually, the fitment appears to be nicely fit. The rear bulges out a bit... but that's expected when 245 series tire is just flush with the rim, putting 275 series tire is going to bulge out.
I bought the tires from America Tires and they were priced at:
275/40/18 $228 per tire (rear)
245/40/18 $150 per tire (front)
Doh:
I thought the rim sizes were 8 all around. I didn't really bother to compare the wheels when the tires were off (I should have!) so I can't vouch to this statement. The owner's manual is kinda not specific enough. But if you look in the Z catalogue, it is more specific. This is what is says:
WHEELS AND TIRES
17"x7.5"(front)/8.0"(rear) 7-spoke aluminum-alloy wheels (350Z, Enth. Tour)
18"x8.0"(front)/8.0"(rear) 6-spoke aluminumalloyw wheels (Perf, Tour)
18"x8.0"(front)/8.5"(rear) Rays super lightweight 6-spoke forged-alloy wheels (Track)
So, my Touring 6 Spd would be 8" all around.
but as far as the fitment goes, there is no rubbing so far. So it should be alright.
Old Dec 28, 2002 | 04:20 AM
mcclaskz's Avatar
mcclaskz
Wow! I didn't you could put 275s on! Anyone know if this is generally a bad idea? These are the tires I wanted to put on some VOlK wheels, but if I don't have to, I won't. How bad is the tire wall flex?
Old Dec 28, 2002 | 06:50 AM
wadd3456's Avatar
wadd3456
He just said ........the side wall bulged a little but not bad.
Im worried that on my 19s it will be WORSE since there is 1/2" less side wall
Old Dec 28, 2002 | 06:51 AM
Stone Z's Avatar
Stone Z
Exclamation
I would not put 275's on an 8" wide rim, whatsoever!
Old Dec 28, 2002 | 06:54 AM
wadd3456's Avatar
wadd3456
Because?????
Do you have personal experience with some sort of horry story?
Old Dec 28, 2002 | 06:58 AM
Stone Z's Avatar
Stone Z
Originally posted by wadd3456
Because?????
I have no personal experience with this exact setup, but from everything I've read (from very knowledgable sources) and from setups I've seen in the past where too wide of a tire was mounted on a rim that was too narrow, I wouldn't do it. There's a reason why certain sizes are recommened for certain widths....not only is it unsafe, it will have a negative affect on quite a few characteristics of the car, not to mention the fact of the bad tire wear.
I just wouldn't do it.
Old Dec 28, 2002 | 07:49 AM
Throbber's Avatar
Throbber
Just curious......Do the Nitto's squeak or roar when spinning out?? Can you even spin a 275??? Im either ordering the Nitto's or the Dunlop SP Sport 9000. Anyone had experience with both these tires to make a comparison? Something about the nitto's low price makes me nervous..
