mismatched set question
I was able to get the front tires replaced by nissan as a result of the feathering issue @ about 9k miles - however now the back tires are about done and I don't exactly feel like dropping $600+ to replace the OEM Potenzas.
I was thinking about replacing the rears w/BFG G-Force 225/45 for my stock 2003 coupe (18" wheel)
Is anyone else using this combination on their Z? Good idea, bad idea?
Thanks in advance
Thanks in advance
For best handling and performance, I recommend replacing all tires at the same time. That said, new tires on the same axle are OK. I would avoid mixing summer performance with, say, all season tires.
With the combination that you mentioned, the Z will handle differently, but neither better nor worse.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
