what is the widest I can go in rear w/o rolling fenders
Old Nov 3, 2005 | 08:17 AM
rodH's Avatar
rodH
Default what is the widest I can go in rear w/o rolling fenders
I have 10" rear wheel, but I want it to come out just a bit more. I am already running +29mm offset and added a 5mm spacer, but want a bit more, but do NOT want to have to roll the fenders. do I go 10mm spacer, 15? 20?
Old Nov 3, 2005 | 08:20 AM
del105's Avatar
del105
15 f125
measure it?
Old Nov 3, 2005 | 09:45 AM
XLR8SN's Avatar
XLR8SN
I think that it was about +22 on a 10.0 wide rim.
Probably can go to about +20 safely though.
Old Nov 4, 2005 | 10:35 PM
rodH's Avatar
rodH
so should I get a 10mm spacer or 15mm??
Old Nov 4, 2005 | 11:12 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you have 275/35/19 in the rear, I would say you can go 10mm (assuming overall offset becomes +19) safely without rubbing. 15mm is pushing it but might work. Consider that I rubbed with a 285 tire on 10.5 +23. According to offset calculator, your wheel at -15mm would extend 3mm beyond where mine was.
Camber will definitely come into play in the 15mm spacer scenario. More negative camber will be safer...
Ask a professional though, just to be sure.
Old Nov 5, 2005 | 10:41 AM
BOMEX180's Avatar
BOMEX180
TO be safe just get a tape measure. Looking at teh given number, I would go with 15 or 20. Yes camber will come in to play
Obadabot
Jun 18, 2023 11:31 PM
