Help with Rims!!!
Old Nov 11, 2005 | 10:36 AM
RBT350Z's Avatar
RBT350Z
Default Help with Rims!!!
I need a bit of help, I have a 350Z Auto Touring. I'm looking to buy Rims, and Actually my plans are to buy centerline rims. I'm hearing rumors that the Auto Touring can not hold anything more than 17's does anyone know if this is true? If not does anyone know the measurments for the wheel bolt circle for 17 or 18 in rims? also, what should the offset be? Thanks everone,
Drive Fast!!
Old Nov 11, 2005 | 10:45 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Totally false...
you need 5x114.3 bolt pattern, roughly max of 19x9.5 +28 front 19x10.5 +23 rear, (disregarding 20")
Just check tire calculators and offset caculators if you need more help with fitment, and keep searching the forums for ideas and sizing info.
Old Nov 11, 2005 | 10:56 AM
RNL323's Avatar
RNL323
Mod My Ride
FALSE... regardless of your trim level you can fit 17-18-19-20 with 5x114.3 bolt pattern. Just make sure you have the right tire size and offsets
Old Nov 11, 2005 | 12:28 PM
SP Racing Parts's Avatar
SP Racing Parts
Tire Sizes you need
19" 245-35-19 front 275-30-19 rear
20" 245-30-20 front 275-30-20 Rear
Old Nov 11, 2005 | 12:31 PM
002-M-P's Avatar
002-M-P
Originally Posted by SP Racing Parts
Tire Sizes you need
First you NEED to find the size wheels you like best (don't just get 20's cause they are the biggest unless thats what you like), then what rim width you want, then what offset is needed for that rim width.
Old Nov 11, 2005 | 03:21 PM
NiSmO D1X's Avatar
NiSmO D1X
I'm running 245/35/19 and 275/35/19; but i'm about to run 285/35/19 soon
Old Nov 12, 2005 | 01:47 AM
RBT350Z's Avatar
RBT350Z
Ok thanx for all the input, Does anyone know what tire size and offset is needed for 18's and also what about the width, should that stay the same? I plan on gettin Falken Azenis RT-615's with Centerline Viking rims....appreciate the Help.
Drive Fast!!!
Old Nov 12, 2005 | 11:53 AM
RNL323's Avatar
RNL323
Mod My Ride
For 18's I would run 245/40 - 275/40. It depends on your wheel width. If you go 10.5inch rears, you might have to go with a diff size tire than 275/40
For 19's 245/35 - 275/35 .... Some people run 30s on the rear but I went with 35s to fill the gap and to provide a little more rubber in case I hit a pot hole
Old Nov 12, 2005 | 02:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I wouldn't recommend 275/30/19 either. 35 is more appropriate for the Z IMO
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
