Wheel spacers
Old Nov 21, 2005 | 01:32 PM
bbhiznors's Avatar
bbhiznors
Default Wheel spacers
Any one have wheel spacers on the stock rims....im interested in getting some to hold me over until i can afford my rims...I need some info ...
where do i get wheel spacers at
how much do they run typically
what kind (size) i need to use
and any handling/user issues any one knows of
btw kind of a novice w/ this stuff
Old Nov 21, 2005 | 02:34 PM
03Z33's Avatar
03Z33
If you want no hassles just better fittment run:
For Touring/Track 18" wheels
15mm front and 20mm rear spacers from H&R. They come with replacement longer studs and will bring your stock wheels almost flush with the fenders.
For Base 17" wheels
20mm front and 20mm rear spacers from H&R. They come with replacement longer studs and will bring your stock wheels almost flush with the fenders.
If you want more aggressive fitment (roll fenders/strech tires) run 20mm front and 25mm rear.
you can purchase these from any H&R distributor, including www.mynismo.com They are around $80-$100 per pair. These are hubcentric so there are not balance/safety issues.
Old Nov 21, 2005 | 05:46 PM
spdu4ia's Avatar
spdu4ia
i have the 20mm H&R wheels spacers with lugs if you are interested... PM me and we can work out a price.
i used them for about 200miles with my stock wheels before upgrading to new rims. sits flush with fender and no rubbing issues.
Old Nov 23, 2005 | 03:42 AM
bleunetizen's Avatar
bleunetizen
I run 22mm front and 25mm rear with stock rays
Old Nov 23, 2005 | 03:48 AM
TiPIACE's Avatar
TiPIACE
i have 15mm H&R DRM on my rear Ann rims, and used the spacers for the same reason you want. Front wheels are stock
looks great and fills the guards perfectly. I painted them black to blend in with the disc hubs
i bought them off a member here in Aus
though the Ann rims have a different offset, 20 or 25 would be the equivalent on 18" stock rims. I have a set of 25mm H&R DRM style if you're interested. They are heavy though, shipping may be expensive
http://img.photobucket.com/albums/v2...e/126_2608.jpg
http://img.photobucket.com/albums/v2...e/125_2580.jpg
http://img.photobucket.com/albums/v2...e/125_2571.jpg
Old Nov 23, 2005 | 04:01 AM
cox's Avatar
cox
On my 35th... i have 30mm spacers per axle in the front and 40mm spacers per axle in the rear...
The spacers are Eibach...
Old Nov 23, 2005 | 04:11 AM
TiPIACE's Avatar
TiPIACE
edit.......just jerried per axle
Obadabot
Jun 18, 2023 11:31 PM
