Forced Induction Traction Problems No More !!!
Old Dec 1, 2005 | 11:41 PM
JETPILOT's Avatar
JETPILOT
Default Forced Induction Traction Problems No More !!!
If your running 19" 's and having trouble getting traction and are looking for an R compund tire safe for wet use to hook up with look no further. Your problems are now solved.
Front PZero Corsa Direzionale
Rear PZero Corsa Assimetrico
If you can't hook up with a set of these in the 295 size you aint got a prayer.
R compound w/a treadwear of 60 !!!!
Pirelli says the tire system uses the 255 PZero Directionale on the front size 255/35/19 to evacuate water so this 295/30/19 slick with a bit of tread can function in the wet.
Finally an R-compound in a 19" sizes in the correct width and aspect ratio to fit the Z........ Yippieeeeee !!!!!
I just bought a set. I'm saying goodbye to loss of traction with my turbo power.
BTW.... these are not cheap !!!!!
Respect
JET
Old Dec 2, 2005 | 04:19 AM
002-M-P's Avatar
002-M-P
good god those are expensive 300-540 per tire is insane
Old Dec 2, 2005 | 04:33 AM
zillinois's Avatar
zillinois
Corsa's are pretty decent. I had them on my formerly heavily n/a modded z and could still break them loose in second. They are very good on a road course though. They are very slippery before they are hot, so be careful when you first jump in the car. Let them get up to temp and then enjoy the sticky.
Old Dec 2, 2005 | 04:42 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I bet these handle great and are better than most street tires but as far as drag racing and getting traction out of the hole, a set of $300 drag radials would own these
Old Dec 2, 2005 | 05:15 AM
zillinois's Avatar
zillinois
I didn't want to be the one to say it.
Old Dec 2, 2005 | 06:11 AM
ALong's Avatar
ALong
Whats the point, why not go with 18" wheels and have a huge selection of race tires to choose from, not to mention lighter wheel/tire combinations to keep the unsprung weight down. The only reason I could see for running 19" wheels with race tires is for clearance of 15 or 16" Brakes.
Old Dec 2, 2005 | 08:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Because some people like the look of 19's and wide rubber. IMO most aftermarket 18's look too small, although they may be wide. BTW they are not all heavy, my 19X10.5's are 20.8 lbs, thats 7 lbs lighter than the factory 18" performance/touring rims....
Old Dec 2, 2005 | 08:59 AM
Phatmitzu's Avatar
Phatmitzu
Good find! but R compound w/a treadwear of 60 Im not sure if I can afford that daily driving my car
Because we are pimps.
Old Dec 2, 2005 | 09:18 AM
JETPILOT's Avatar
JETPILOT
They don't make 19" drag radials. I need a tire that will not compronmise handling. I want my 19" wheels, and I want sticky tires. There are lots of us with 19's that want to hook up under boost. It's not that I like the look of wide rubber. It's a necessity for traction with Turbonetics.
Respect
JET
Old Dec 2, 2005 | 09:29 AM
sentry65's Avatar
sentry65
the burninator
so how long do those tires last?
yeah I'd be much more likely to run street legal competition tires than drag radials on the street
Old Dec 2, 2005 | 09:33 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Respect
JET
I know they dont make 19" DR's, Im hoping my 285/35 19" KDW II's will be enough to get going ok with my Turbonetics kit. I know it wont be easy, but it can be done. I wouldnt spend so much on those tires in 19's, Id just mount my slicks when I wanted to bust somebody's a$$ from a dig, or put my stock track rims on with DR's for much cheaper.
Uriyo_
Sep 8, 2021 08:46 AM
