Staggered and wheel size question.
Old Dec 4, 2005 | 08:50 PM
superleo's Avatar
superleo
Default Staggered and wheel size question.
Hi Guy
Proly this is a bump question. I tried to get myself a rims for the frist time. It's a staggered and typical rims (same size on 4 rims) on the market. Of cause, staggered make the car look much awesome than the typical rims. However, they are much expensive, too.
I look around this forum around the rim size. They all suggest to get a staggered wheel. Because the VDC computer only work correctly, when front wheel is a bit smaller than the rear wheel.
Is it a delimma? Can Z only get staggered rims intead of typical rims? Can Z get a typical rims, but wear a bigger tire on the rear?
Thank for helping!
Old Dec 4, 2005 | 09:02 PM
Staggered wheels as in 18 inch wheels in the front and 19 in the rear? Sure. Why not.
If you want, put 8 inch wide wheels on front, and 9 in the rear. No problem.
Old Dec 4, 2005 | 09:59 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
As a mater of fact, the stock performance/touring wheels are all 18x8 with the back being a slightly taller tire. So if you want to get all four wheels the same, you can do that as long as you fit tires with the proper stagger.
Chris
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
