Cant find a tire to run on the 19s!!
Old Jan 11, 2003 | 06:43 AM
wadd3456's Avatar
wadd3456
Default Cant find a tire to run on the 19s!!
Well since 275s are too wide on an 8" rim I cant do that. I also want to keep the rev/min similar and I cant seem to do that with any other comparable size.
There is no 265's.
255 40 19 has 246 rpms instead of 256 rpms (so thats off) plus its .3" taller then stock.
245 is way too small for the back.
What the heck am I supposed to do? Errrr.
Old Jan 11, 2003 | 07:43 AM
jak's Avatar
jak
Default Re: Cant find a tire to run on the 19s!!
There is no 265's.
Use 255/35/19. That is what I will be using. When spedo reads 60 mph actual would be 59.5 mph. Which is acceptable to me.
Old Jan 11, 2003 | 02:38 PM
wadd3456's Avatar
wadd3456
I was told the potenzas done come in 255 35 19 ?
What tire are you running. Please respond asap because im ordering them tomorrow.
Thanks
Old Jan 11, 2003 | 04:33 PM
jak's Avatar
jak
Thanks
Old Jan 11, 2003 | 04:41 PM
jak's Avatar
jak
Thanks
That size is available by Pirelli, Continental, and Toyo. I've had Pirellis and they don't last long so I am using Continental Contact 2s. I here the Toyo Proxies are nice also.
Old Jan 12, 2003 | 05:26 AM
wadd3456's Avatar
wadd3456
Out of curiosity, what did you pay per tire and what width rim are you running?
Thanks
Old Jan 12, 2003 | 06:10 AM
jak's Avatar
jak
$259.00 at Tirerack. I am running a 9" rim. The published rim width range is 8.5 - 10 inches but I would think you could get that on a 8" rim.
Old Jan 13, 2003 | 01:41 PM
wadd3456's Avatar
wadd3456
Is each car calibrated to rim size? The 17 rears arent near the 18 rears in size Should i get close to my 17s or your 18s?!?!
Old Jan 13, 2003 | 02:55 PM
wadd3456's Avatar
wadd3456
Yeah i know /understand that , but my questoin is slightly different.
People are trying to match to the 18s. I have 17s.......matching to them would be different then matching the 18s. Do i want to be closer to 17s or 18s
Old Jan 13, 2003 | 03:02 PM
jak's Avatar
jak
Match to what you have. If you have 17's (768 rpm) then 255/35/19 is closer than 255/40/19. If you have 18's from the factory then 255/40/19 is closer.
Old Jan 13, 2003 | 08:59 PM
exa4driver's Avatar
exa4driver
maybe you should switch to a wheel with a staggered pattern
Workshop12
Mar 23, 2020 01:45 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
FromGtoZ
Sep 20, 2015 03:41 PM
