pic of stock Track rims with 245/F and 275/R
Old Jan 12, 2003 | 08:46 PM
wizeline's Avatar
wizeline
Talking pic of stock Track rims with 245/F and 275/R
Okay, I put S03's on here just a couple of days ago, tell me what ya think??
245/40/18 front
275/40/18 rear
they drive well, and I think they fill up the wheeel well perfect. Also, I have tried hard to make them rub, and I can't!! No problems at all.
Attached Thumbnails pic of stock Track rims with 245/F and 275/R-dsc004421.jpg
Old Jan 12, 2003 | 08:54 PM
Selski12's Avatar
Selski12
Looks good to me. More aggressive look.
Old Jan 12, 2003 | 09:17 PM
wizeline's Avatar
wizeline
thanks... They are what should have comeon this car in the first place I think.
Old Jan 13, 2003 | 03:24 AM
wadd3456's Avatar
wadd3456
Ak, yet another person throws a 275 on an 8.5" rim. Hmmm.
Can you take a close up of the rear tires so I can see if their is any bulge? Thanks.
Old Jan 13, 2003 | 05:28 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default WOW!~
245/40/18 front
275/40/18 rear
It looks great, decisions, decisions....
So how much did it end up with everything? tires/mounting/balancing, etc..
Old Jan 13, 2003 | 06:02 AM
articfury's Avatar
articfury
Charter Member #55
I don't see why people insist on going against the tire manufacturers recommendations.
The proper rim width for a 275 is 9.5", a full inch wider than the Track Ray's.
Not only could your maximum performance be adversely affected, but so could your safety.
JD
Old Jan 13, 2003 | 07:20 AM
wizeline's Avatar
wizeline
First off, the tire buldge is minimal... I'll take a pic later on tonight.
Secondly I like the agressive looks not the true preformance gain. I know that less rolling resistance mean greater speeds, but comeon... how many of you are really racing anyway. Just a few the rest like the feel anmd look of this car.
Thirdly, the "minimal bulge" is going to protect my rims... on the stock 225 fronts, the rim lip sticks out and will hit the curb first. I would much rather replace a set of $200 tire than cry about not having the money for a new $800 rim!!
Lastly, the tires, balance, and install cost me $905 total after tax.
I startted to go with the Kumo MX tires, but the S03's just looked better.
Old Jan 13, 2003 | 07:42 AM
articfury's Avatar
articfury
Charter Member #55
wize,
I have nothing against going with a wider tire purely for the aesthetics, if it properly matched to the wheel size.
I do like the feel and look of the car. But I also know that I will drive the car "aggressively" at times. I would rather not have a tire failure at that point, which is a possibility when using a tire out of spec.
This subject has already been discussed, at least one other time that I know of. Here is a thread where we discussed this, albeit on the 18x8" wheel. The Ray's are still out of spec for the tire. If you want to run 275s, you should buy some 9.5" wide wheels, or at an absolute minimum 9".
If you don't want to believe me, then how about Bridgestone.
JD
Old Jan 13, 2003 | 09:10 AM
wizeline's Avatar
wizeline
This is directly from Bridgestones web site. The front tires meet the Bridgestone recs. The rears are only .5 shy. This is very typical on rims and + or - .5 is very reasonable. When you do plus size a bit like this you simply need to monitor air pressure. I just drove the hell out of my car in Marin County. See Nor Cal Regional Forums. And the tires were great.
245/40R18 recomended rim 8.0-9.5
275/40R18 recommended rim 9.0-11.0
If you are driving hard enough to make a set of S03's on a 8.5 J VOLK Racing rim fail, you should not be on the road.
Again, the tires do not scrub or act at all "funny" on the road. if you are exceeding this tire and rim combo, you are probably already dead.... be careful out there and be reasonable.
Old Jan 13, 2003 | 12:10 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
wizeline: can you post more pics? Thanks!
Old Jan 13, 2003 | 12:22 PM
wizeline's Avatar
wizeline
I'll take the wheels off the car and post more pics here later tonight.
My general reason for posting, was to see if this "mod" made the car noticibly better looking to anyone??
Let me know what pics you want (angle/side) and I'll post them tonight.
Old Jan 13, 2003 | 12:52 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
behind the car view *lower section* (to see how wide it is)
close up view on the rear tire sidewall (to see the bulge)
car side view (too see the clearance)
That's it for me.. Thanks!
BTW, anyone here have pics of 275 on 18x8 rim?
Old Jan 13, 2003 | 02:53 PM
articfury's Avatar
articfury
Charter Member #55
I guess you have never been in a situation where quick, extreme maneuvers are required.
The fact that you are willing to run a tire that you admit is out of spec for the wheel size, illustrates that logic will not help dissuade you from this path. I truly hope that your luck does hold and that you don't experience any issues.
The downside is that others will see that you have done it and say, well it works for him so it will work for me. I know, I know, they are big kids, but group mentality is a strong force.
I hope that everyone considering 275s on stock rims really analyzes the importance of looks versus the possible danger to themselves and others. Is it really all that important?
JD
Old Jan 13, 2003 | 04:40 PM
wizeline's Avatar
wizeline
articfury,
I am happy to hear that you are concerned about the safety of other. It is very responsible.
Old Jan 13, 2003 | 04:52 PM
wizeline's Avatar
wizeline
I understand where you are comming from, and Bridgestone recommends a .5 larger rim for the 275's. But Wheel Works recommend 8.5 J max, and every other shop/company has a .5 or greater deviation.
I am not trying to win a race, or tear up the roads. My intent is to add to the look, and stance while still having a "safe" vehicle. This car is safe. I have been to three diffrent shops toay because you got me all riled up.
I am happy with these tires and they preform perfectly, even on the twisties, and in senior citizen traffic. If you are not comfortable with a tire that is not recommended, don't use it.
Don't contine to give me any grief about how millions will follow. The simple response is, "Would you jump off a bridge just cause I did?" I think the whole way through this I have siad nothing but take care when you are driving, and not to race around. Those are the only ones that could possibly hurt this tire/rim combo.
If you wish to discuss the Pro's and Con's of this tire size, start a thread. My question remains.... "Do they look good?"
Sorry for going on and on, but I made my decision, even after reading all the forums about it. Let others make thier own decision or become a preacher and do it the right way.
Old Jan 13, 2003 | 05:03 PM
wizeline's Avatar
wizeline
rear flush
Attached Thumbnails pic of stock Track rims with 245/F and 275/R-rear.jpg
Old Jan 13, 2003 | 05:04 PM
wizeline's Avatar
wizeline
rear (tire)
Attached Thumbnails pic of stock Track rims with 245/F and 275/R-rear-blank.jpg
wizeline's Avatar
wizeline
rear angle
Attached Thumbnails pic of stock Track rims with 245/F and 275/R-rear-side.jpg
