LE28N 19x10.5" +22 and tire sizing
Old Jan 11, 2006 | 02:12 PM
Z33GRIP's Avatar
Z33GRIP
Originally Posted by GMADD
What's the widest I can go with a 19x10.5 +26 offset ?
This is for the G35 coupe
Thanks !
a friend of mine has a G35 coupe with 19x10.5 and is running a Falken 285/35-19 with no rubbing/no problems. Tire stretch is minimal as well.
Old Jan 11, 2006 | 06:12 PM
Will Pwr's Avatar
Will Pwr
Originally Posted by Alberto
I have that set-up. Im lowered pretty good, and on very fast cornering I rub slightly, or when driving over an incline while turning. Other than that no rub, you'll be fine.
Thanks...Ill be running the same set up then...currently with my 245 & 8.5 set up its fine, so with my new 9.5 set up I really wanted to go 255
Old Jan 11, 2006 | 07:32 PM
ActionJackson's Avatar
ActionJackson
Originally Posted by disturbed2483
im running 19x10 +20 with a 285 on a 2in. drop and no rubbing issues.
Probably because your tires are tucked in due to all the negative camber
Old Jan 12, 2006 | 04:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by BhashaZ
Alberto, do you rub on the inside or outside? I'm assuming that you have 19x9.5" +22 on the front? I have 19x9.5" +19, so I'm wondering if it will rub if I go with the BFG's in 255/35.
The outside of the tire rubs slightly....its because of my drop more than th etire size and offset though.
