Quik tire question
Old Jan 16, 2006 | 02:07 PM
GMADD's Avatar
GMADD
Default Quik tire question
I currently have 275-35-19 potenza S03 and I want a larger tire so if I go 295-30-19 would the sidewall be that much smaller ?
We have lots of pot holes here in Montreal so I can't go too small.
Thanks !
Old Jan 16, 2006 | 03:22 PM
barthelb's Avatar
barthelb
Master
without looking at tire rack I think the best fit other than what you have is a 305/30/19 because the 295 is a lil smaller. Im not sure but I might have that backwards so check them out. Stock diameter for rear is 26.8". Front is 25.8 So if I were to guess, I think VDC is happy as long as the Front/Rear bias is only 1" or maybe just near to those diameters.
Old Jan 16, 2006 | 04:18 PM
GMADD's Avatar
GMADD
Would a 305/30/19 fit on a G35 coupe with a 10.5 +26 ?
do I need to roll my fenders ?
Thanks !
Old Jan 16, 2006 | 06:36 PM
SilverII's Avatar
SilverII
Thanks !
are you dropped? if not, you might just make it with little camber
Old Jan 16, 2006 | 06:49 PM
GMADD's Avatar
GMADD
Thanks,
No I'm not dropped and I have the Kinetix adjustable camber arms.
Old Jan 17, 2006 | 09:12 AM
barthelb's Avatar
barthelb
Master
That offset will make it real close. G3po has a G35 with SSR's and he has a 295/40/18 in the rear and he can go maybe 2 or 3 sizes larger. He has a ton of room, but i dont know the offset on those rims. Mine are +31 in the rear and I think mine will be very close.
Thanks !
Old Jan 17, 2006 | 10:28 AM
GMADD's Avatar
GMADD
I think I'll try 295/35/19 next and see if I have more room for a bigger size later on.
Old Jan 17, 2006 | 10:51 AM
You mention two tires sizes. Do you know how to calculate the sidewall height of each?
Old Jan 17, 2006 | 01:02 PM
GMADD's Avatar
GMADD
I do but maybe using two different tire models wouldn't be the same,
I'm using the 275/35/19 S03's now and I want to try the 295/30/19 KDW's.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
