track wheels + spacers + s-tech (pics)
Old Feb 7, 2006 | 07:25 AM
Zendem's Avatar
Zendem
Arent you suppose to purchase something else besides just the hubcentric spacers...what if the screws arent long enough and you can't bolt the wheel on properly because you have 25mm or something around that range
Old Feb 7, 2006 | 07:33 AM
BhashaZ's Avatar
BhashaZ
Originally Posted by Bubble
so if my rear offset now is 29. I want it push outside a bit more, what spacer should i get? a - 5 spacer? so that i can get something equal to 24 offset?
That's exactly what I did and I think it looks perfect now. I had +29 on a 10.5" rear, and by adding a 5mm spacer, it is essentially 10.5" +24.
Old Feb 7, 2006 | 07:56 AM
pj550v12's Avatar
pj550v12
Thats how the cars stance should have been from the factory, very nice looking.
Old Feb 7, 2006 | 09:15 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
how much did you paid for your 5mm spacer? what brand? and where?
Old Feb 7, 2006 | 09:22 AM
bixby's Avatar
bixby
Originally Posted by MustGoFastR
Hmm, they look very agressive from those angles; not bad. Problem I have with 25mm spacers on the rear with stock size tires is that from a straight behind shot (got one of those?), the wheels look like they are spread too wide.
I have an '03 Track and have a two-stage goal for my wheels.
Stage 1: 15mm spacers rear, 10mm front. This brings them to within 1mm of the Nismo LMGT4 wheels' offset, which is the look I am after.
Stage 2: (when I need new tires and have more cash...) move the rear wheels up front with the 10mm spacer (will just stick out another 3mm), put 245/40-18s on them, have the front wheels widened to 9.5 or 10", put them out back with 275/40-18s and 20mm spacers. I'll essentially have Nismo rims at a tiny fraction of the cost.
I've got 265/40's on my rear Ray's & 245/40's front. They fit quite nicely without widening. I like the spacer look and think I may give it a try.
Old Feb 7, 2006 | 09:25 AM
BhashaZ's Avatar
BhashaZ
I paid like $20 or something. They are a generic brand and not hub-centric. When I talked to Chris at F1 when I originally bought my wheels, he said if you're only getting 5mm spacers, they don't need to buy hub-centric. I actually ended up buying them from Rick @ Status, and he also told me that with a 5mm spacer I didn't need to go hub-centric.
So far, no problems *knock on wood*
Old Feb 7, 2006 | 10:09 AM
Silkk's Avatar
Silkk
Yeah, I've always heard there is no need for longer studs on 5mm...
Otherwise, yes, hubcentric with longer studs are essential.
Car looks good!
Old Feb 7, 2006 | 10:40 AM
plastiketa's Avatar
plastiketa
dsmal-
What's the camber setting in on the rear? Is it to spec?
Old Feb 7, 2006 | 11:07 AM
MustGoFastR's Avatar
MustGoFastR
Yeah, I know those will fit; I just prefer the slightly stretched look for the tires. Heck, the '06 Track has 265s stretched on 10" rims on the rear! It's only like $170 a wheel to have them widened, so when I'm ready, I'll probably just go that route.
Old Feb 7, 2006 | 12:06 PM
JDMFairlady21's Avatar
JDMFairlady21
wat kind of exhaust is that?
Old Feb 7, 2006 | 03:23 PM
RNL323's Avatar
RNL323
Mod My Ride
Did you do the spacer install or did you take it to a shop? I've been thinking about adding 10mm in front and 15mm out back. I have 19's but with stock-ish offests. I want that aggressive look! I'd like to do it myself though rather than paying for the install.
Just by doing research, it looks like you have to take off the calipers, then the rotors to install the longer bolts?
I've only worked on the engines of the cars I've had, never the wheel/brakes/rotors area so I would be feeling out the install on my own...
Thanks in advance for you input!
Old Feb 7, 2006 | 03:25 PM
RNL323's Avatar
RNL323
Mod My Ride
Did you have to use longer bolts for the 5mm spacers?
Old Feb 7, 2006 | 04:03 PM
BhashaZ's Avatar
BhashaZ
No. I only used spacers because that's all that they said I needed.
Old Feb 7, 2006 | 10:26 PM
dsmal's Avatar
dsmal
No, I did the install myself, but these spacers had their own studs, so it was a bolt on affair. I've installed studs before, ghetto style. Remove caliper/rotor, tap the stud out, remove from behind, insert new one and pull in using washers and lugnut. This was on a friends altima long ago, studs are still good many years later, but I'm not sure if its this easy on the Z.
My camber is not in spec, I haven't gotten it aligned as my tires are quite worn, I'll do it when I buy a new set.
al
Old Jun 14, 2006 | 11:36 AM
350Zenophile's Avatar
350Zenophile
Resurrecting this thread...dsmal, what size tires are you running on your track wheels?
Bixby, got any pics of your 245/265 setup?
Thanks
Old Jun 14, 2006 | 03:01 PM
bixby's Avatar
bixby
Here are the 265/40's on the 18x8.5 Ray's. No pic's of the fronts.
Attached Thumbnails track wheels + spacers + s-tech (pics)-26540s1.jpg   track wheels + spacers + s-tech (pics)-26540s2.jpg
Old Jun 14, 2006 | 03:59 PM
solidsnake's Avatar
solidsnake
Are you still using stock lug bolts? i got 15mm and i know the stock bolts wont have enough thread to hold...
Old Jun 14, 2006 | 05:56 PM
  #38
350Zenophile
My My, those do fit nicely. I was thinking 255s in the rear to dial out a bit more understeer. With 245/40 up front and 255/40 out back the height differential is only 8mm (rear biased). It seems that VDC and ABS are only affected when there is a front bias...I mean loads of people are running even height tires without a problem, right?
Bixby, was that picture taken on stock suspenders? I don't see any springs in your sig. Thanks for the quick post! I'm planning on placing an order tomorrow.
Old Jun 15, 2006 | 06:49 AM
  #39
bixby's Avatar
bixby
Yes I used stock but no spacers.
Old Jun 15, 2006 | 06:51 AM
  #40
bixby's Avatar
bixby
No suspension upgrades.
