What size tires on the stock 18" wheel?
Old Feb 21, 2006 | 03:45 PM
ericjackson's Avatar
ericjackson
Default What size tires on the stock 18" wheel?
ok, kinda hit me by suprise, but i need some rear tires quick. my traction is crap now, my tires have about 10% of tread left.lol. i was planning on saving money just the other day to get some better tires anyways, this is just making me speed up a bit.
i need to know what size tires would everyone rec for the stock 18's on my 03 Z. i was thinking of doing 255/?/18, but im not sure if i should get 40's or 45's, i want to stay around stock diameter. but im not sure how to calculate it.
also, what sizes would you all rec for the fronts too? thanks
and i was looking at these tire here, what do you all think about them?
http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
they are supposed to be #1 for max summer tire, thanks ahead of time
Old Feb 22, 2006 | 04:14 PM
ericjackson
no one knows what size to get?
Old Feb 22, 2006 | 04:21 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
stock: front 225/45/18 rear 245/45/18
sidewall~ front 101.25 rear 110.25
if you goto a 255, stick with a 45 ratio with a 114.75 sidewall instead of a 40 with a 102 sidewall (measurement are in mm) but if you goto 265 drop to the 40 and a 40 on 275. The goal is to stay as close to the oem sidewall.
if you have vdc, try to keep the number as close to oem as possible, a 275/40 is a better ratio than the 265/40 and a 255/45.
hope that helped
Old Feb 22, 2006 | 04:31 PM
ericjackson
well tell me this, would you rec getting 245's on the fronts? ive heard that the Z's come with to skinny of front tires anyways for their suspension
Old Feb 22, 2006 | 04:36 PM
dixieland's Avatar
dixieland
I just replaced my stock:
front - 225/45/18
rear - 245/45/18
with:
245/45/18 all the way around. Did quite a bit for the understeer in sharp turns.
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
