stock track wheel guys...question
Old Mar 3, 2006 | 12:55 PM
BigZ88's Avatar
BigZ88
Default stock track wheel guys...question
Like it says guys....there is no good thread for people with the stock wheels and plausible tire sizes and upgrades. I'm not looking to spend a fortune, or run a track only tire. I've been fairly happy with the size and look of the tires i have now. I have noticed that going to a 225/40 and 245/40 combination opens a whole new door to tire brands and prices. I was wondering if anyone had done this and what effects it may have had.
I was thinking of going up in width, but what is an acceptable width to go to on the track wheels?
excuse my ignorance on the topic, but i came from a honda community with a civic that had 15" wheels, and a 205/50 was the standard size that everyone was running for the most part.
Old Mar 3, 2006 | 01:07 PM
dubbzdiggler's Avatar
dubbzdiggler
You need to stick with the staggered set up Nissan put on the vehicle. The 40 series on the 18" wheels aren't going to carry the suffient load capacity. The only way you can go 40 series is if you go with a larger section width...245f and 275r. But you can't do these sizes on the stock widths. Plus, if you were to avoid the load capacity warnings, you'd notice a HUGE wheel well gap by going with 40 series on 225 and 245.
Old Mar 3, 2006 | 02:00 PM
Click here for more than you ever wanted to know about wheels and tires for the 350Z
http://www.350zmotoring.com/modules....ex&name=Wheels
Old Mar 3, 2006 | 06:04 PM
streetracer's Avatar
streetracer
I run 255/45 on my base 03 on the back and they have perfomed ok to me. Im installing Track wheels now and will probably go for 265/45, 265/40 or 275/35. Im searching to install used good tires, so whatever I can find in those sizes will do.
Old Mar 4, 2006 | 05:03 AM
Zilvia's Avatar
Zilvia
running 255/35 AND 265/35 Pirelle P Zero Cossa(R compound), so the grip is way sticker that a Street tire, i use these for Tracking. Its an awesome combo
Old Mar 5, 2006 | 07:29 AM
BigZ88's Avatar
BigZ88
well atleast the size is relavant. Tire choices are just so limited in the stock size. not to mention expensive!
Old Mar 5, 2006 | 04:35 PM
Zilvia's Avatar
Zilvia
no tires for 18" wheel are pretty cheap
compared to that of 19s
Old Mar 8, 2006 | 04:07 PM
BigZ88's Avatar
BigZ88
well, also a reason why i'm not looking to go to a different wheels.
what is a common plus sized tire for track wheels?
Old Mar 8, 2006 | 07:02 PM
Kolia's Avatar
Kolia
I run 235/40R18 and 255/40R18
Old Mar 12, 2006 | 11:47 AM
BigZ88's Avatar
BigZ88
what brand tires are they? its rare to find a matching set in those sizes
Old Mar 12, 2006 | 04:01 PM
Kolia's Avatar
Kolia
Falken Azenis RT-615.
You will be slightly underdriven (Indicated speed will be higher than the actual speed.)
You can also get BFGoodrich KDWs in these sizes.
Old Mar 13, 2006 | 06:08 PM
bdblackz's Avatar
bdblackz
I am also looking for a set of the Azenis for the stock track wheels, but found 255/45R18 to be a closer diameter to stock than the 40 profile (1.3% vs. 2.4%). Why did you go with 255/40R18? Are there rubbing issues with the 45 profile and that width??
Old Mar 13, 2006 | 06:36 PM
PDX_Racer's Avatar
PDX_Racer
I'm running 245/40f and 275/40r. No problem getting the tires on the wheels, although the 275s are a bit wide.
Old Mar 13, 2006 | 06:43 PM
Kolia's Avatar
Kolia
Not all sizes were availlable when I first got the tires. And I thought it more important to maintain the front to rear stagger.
Being slightly underdriven is good for acceleration too !
Old Mar 18, 2006 | 09:01 PM
bdblackz's Avatar
bdblackz
i decided to go with 245/40 18 all around for my race tires. That way i can rotate the tires (but not wheels obviously) and hopefully reduce understeer and improve turn in...hopefully...
HoBrahYouStink
Jun 24, 2016 10:58 PM
SharX59
Sep 30, 2015 10:54 AM
Li1ag
Sep 28, 2015 02:07 PM
