tire pressure
Old Jan 26, 2003 | 02:43 PM
hk350's Avatar
hk350
Default tire pressure
wat do i do, when the tire pressure indicator is on, ? do i take my z to the nearest gasstation and fill up the tires? btw, i live in edmonton,ab canada. its -20 here
Old Jan 27, 2003 | 09:12 AM
Luke@tirerack's Avatar
Luke@tirerack
first manually check the air pressure ...
Old Jan 27, 2003 | 09:22 AM
droideka's Avatar
droideka
Default Re: tire pressure
You should ignore it. The tires will fill themselves back up this coming Spring. That is, assuming you can wait that long.
For every ten degrees the temps drop, you can expect to lose one PSI in your tires. If the temps drop overnight, even in a garage, you should expect some loss.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
