new tires of stock 17's
Old Jan 30, 2003 | 08:05 AM
del105's Avatar
del105
15 f125
Default new tires of stock 17's
Im looking for a new set of tires for the my 17inch wheels. My main concerns is that they are close to or slightly larger then original tires and that they have good traction and last. Cananyone recommend a specific tire Im looking for maybe a 225/55/17f or 235/55/17f, 245/55/17r or something along those lines. I know these are slightly larger then original will that cause problems?
Old Jan 30, 2003 | 09:01 AM
del105's Avatar
del105
15 f125
241890 TOYO PROXES T1 245/45ZR17 PROXES T1S 95W $164.00 $328.00
241880 TOYO PROXES T1 235/45ZR17 PROXES T1S 97W $154.00 $308.00
Sub-Total: $636.00
These are some that Iam looking at. Are these a good deal. and is the shorter side wall going to mess up my mileage? Is there any way to ajust to speedo for the new tire size? I figure every 20 miles I drive on these shorter tires I add like 1 mile to my odometer that I didn't really drive.
Old Mar 24, 2003 | 07:42 AM
ACEMAN's Avatar
ACEMAN
Master
Default i also have the 17s
What other tires would you guys recommend on the 17's?
Im looking for something that will hook up alot better than these stock tires. and what is the biggest size tire i can place on the stock rims in the rear?
Thanks guys
Later
Aceman
Old Mar 24, 2003 | 12:50 PM
Clyde's Avatar
Clyde
Default 17" tire size
I'm running Firestone Firehawks. I have 17" stock rims (enthusiast) and I put 235/45/17 on the front and 275/40/17 on the rear. This kept me at spec. with the front to back ratios. From what I understand 245 is the widest you can put on the front without rubbing.
Old Mar 25, 2003 | 05:24 AM
j's350z's Avatar
j's350z
I wouldn't be worried about the front... You put a 275 on the 8" wheel in the back?????????????????????? Thats a big no, no.... Good Luck A 275 should be on a 9" wide MINIMUM..............
sales@czp
Sep 23, 2019 03:30 PM
