Tire sizes: Does keeping them proportional matter?
Old Mar 24, 2006 | 06:49 AM
21112's Avatar
21112
Default Tire sizes: Does keeping them proportional matter?
Ok, lets just say I wanted to get a setup with a 19x9.0" front rim and a 19x10.5" rear rim.
Then let's say I wanted to run a 305/30/19 tire on the rear rim. What would be the best tire to run on the front?
Looking at the stock (base model), the total height from the ground for each wheel (((width x sidewall percentage) x2) + rim diameter) =
Stock
Front: 225/50/17 = 242
Rear: 235/50/17 = 252
The aftermarket setup I was thinking about looks like this:
Preferred setup
Front: 245/30/19 = 166
Rear: 305/30/19 = 202
Option 1
Front: 255/30/19 = 172
Option 2
Front: 245/35/19 = 190.5
Now the variation between the total height of the front and rear tires on the stock setup is only 10. The variation of the setup I was thinking about getting is rougly 40. Is this ok? Does it matter for any reason? I can adjust the suspension differently in the front and back with coilovers to make similar wheel well gaps, but does the different proportions matter for traction/performance/handling?
Option 1 above brings the difference closer to stock by 10 (difference becomes 30), and a 255 tire should easily fit on a 9" rim. However, option 2 above brings it back into the stock proportionality, but I have to deal with the different sidewall height percentages between the front and rear, and I don't know the effects of that (both if it will look good, and if it will handle well).
So, any thoughts........
Old Mar 24, 2006 | 06:59 AM
Tire height matters. Both VDC and TCS are sensitive to tire height. As you mentioned, the OEM 17 inches set-up has a 10 mm difference between front and rear tires. Would I go 30 or 40 mm? Nope.
Old Mar 24, 2006 | 07:02 AM
jcarp's Avatar
jcarp
i would run 255/35/19's its about 0.2 inches shorter
Old Mar 24, 2006 | 07:21 AM
21112's Avatar
21112
jcarp: The 245/35/19 matches the OEM difference. Running a 255/35/19 brings the front and rear heights to almost matching (197.5 + 202). That is closer then the -40 and -30 setups, but it does go in the other direction, being +5.5 over stock difference. So what advantage would this have over the 245/35/19 setup?
davidv: I have a base model so no VDC or TCS. I know proportionality matters for VDC and TCS, but since I don't have either, does it matter for any other reason? (Performance/handling/traction)?
Old Mar 24, 2006 | 10:03 AM
MoodDude's Avatar
MoodDude
Why does VDC care about tire height? Tire height will be more critical for F to R weight balancing (braking and acceleration), and your speedo.
My understanding that you must maintain your tire combo to have understeer, since VDC is programmed to react to this condition?
Or maybe I am way off base?
Old Mar 24, 2006 | 10:09 AM
21112's Avatar
21112
I was told the speedometer isn't hooked into tire rotation, so changing tire sizes doesn't matter. I don't know where the speedo gets it's data from though. Is that true, or am I misinformed?
Old Apr 23, 2006 | 06:52 PM
Stunner2xx's Avatar
Stunner2xx
bump and why do u want to put the 305 in the rear? from my understanding if you put the 305 in the rear u would have to roll the fenders correct?
Old Apr 23, 2006 | 07:21 PM
DavesZ#3's Avatar
DavesZ#3
Yes, you are way off base. VDC/TCS/ABS all depend on wheel speed sensors mounted to each axle. Those sensors monitor the rotational speed of each wheel. If you change to a taller or shorter tire, the # of rotations at a given speed will change.
The computer expects to see the difference between the front wheels and rear wheels within a certain range. When you get outside that range, it can trigger either VDC or TCS.
BTW, there is also a G sensor (accelerometer) in the Z that comes into play with the computer and VDC.
Old Apr 23, 2006 | 07:26 PM
DavesZ#3's Avatar
DavesZ#3
The speed signal comes from the VDC/TCS/ABS control unit which gets speeds signals from each wheel sensor. If you change tire height, you affect the # of rotations per mile which will throw off the speedometer in the car. That's why it's recommended that you keep the tire heights close to stock so you don't have a lot of error in your speedo reading and you won't affect VDC or TCS.
Old Apr 23, 2006 | 07:44 PM
I doubt it. You may have a minor difference in balance and braking with the rear in the air and the front pointed down. But the difference would be trivial.
kyin
Oct 15, 2015 05:54 AM
