Need your help with spacers and lugs?
Old Apr 1, 2006 | 02:30 PM
NM350's Avatar
NM350
Default Need your help with spacers and lugs?
I was told that if I order spacer (15mm) that I would need to buy tuner bolts
has anyone done this or does anyone know what type of new lug size do I need?
Thank you guys!
Im still new to this whole thing!
Old Apr 1, 2006 | 03:16 PM
NM350's Avatar
NM350
btw, I have currently a 35 offset with ADR mSPORTS
thanks again
Old Apr 1, 2006 | 04:36 PM
MustGoFastR's Avatar
MustGoFastR
If you buy decent, hubcentric spacers (H&R or Eibach; try Performance Nissan or look for people selling in the classifieds), they come with longer studs to replace the stock ones.
To replace studs, lift corner, remove wheel, brake caliper and rotor, then shoot lugs with penetrating lube. Get two old lug nuts and cut the cap off one of them with a dremel cut-off wheel to make it open ended. Take the intact nut, screw it onto the end of one of the lugs and tap it out with a heavy hammer (takes several consistent med force hits; don't try to pound them out with a few hard swung ones). slip the new lug in from the back of the hub and screw on the open ended nut until it hits the hub, then tighten it down with a crescent wrench to draw the new lug into the hub. Repeat for the remaining bolts.
When doing the rear, be sure to leave the e-brake off so you can get the rotor off, then when you're doing the lugs, take the car out of gear (make sure it's sitting on level ground and be careful at this point) so you can spin the hub into the right position to be able to get the old bolts out and the new ones in from the backside, around the e-brake guts without having to further disassemble anything. Once you get the hang of it, each corner should only take you about 15-20 min.
Old Apr 1, 2006 | 05:01 PM
NM350's Avatar
NM350
WOW, thanx for the great write up!! exactly what I needed
I actually ordered the 15mm H&R spacer
ill post pics up of before and after
thanx alot!
Old Apr 7, 2006 | 10:44 PM
jlvvega's Avatar
jlvvega
Pics??
Old Apr 10, 2006 | 11:54 AM
Auto RnD's Avatar
Auto RnD
or...
you can purchase project kics that just bolt on to the current studs..
Old Apr 10, 2006 | 01:27 PM
jlvvega's Avatar
jlvvega
Wow you was right that was easy.
Thank you men!!!!!
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
