18in Black Motegi Touge
What do you think? I found these new on ebay for a little over 700. Staggered with +12 offset for front, and +33 for the rear. I believe the fronts were 9-91/2 and the rear were 10. Both front and rear rims have 3in lips. It is either these or Axis Hiros. I like them both.
Guest
Posts: n/a
M-TOUGE has a 3" lip on both the front and rear for the 350Z: 18X9 front,
18X10 rear.
The correct tire aspect from stock would put you at this size...
Front: 255/35/18
Rear: 275/35/18
Tire rack has no clue on the correct tire size. Tire rack tells you to run the factory size. This wide of a wheel would stretch out the dise wall so much, the tire would not bead correctly to the rim.
Use a tire size calculator to check the aspect ratios...
http://www.miata.net/garage/tirecalc.html
18X10 rear.
Front: 255/35/18
Rear: 275/35/18
Tochigi_236
Sep 27, 2015 03:40 PM
