Looking for some help.. Will 2004-6 Acura TL 17" rims fit a 2006 Nissan Altima
Old Apr 9, 2006 | 11:51 AM
drive4fun's Avatar
drive4fun
Default Looking for some help.. Will 2004-6 Acura TL 17" rims fit a 2006 Nissan Altima
Will 2004-6 Acura TL 17" rims fit a 2006 Nissan Altima without a problem. I know they are both 5x114.3. Tires are P235/45/R17. The offset is 45 and I do not know if bore center hub will fit. Can someone please help me out and tell me if it is a direct replacement.
TL Spec's Stock
PCD is 5-114.3 and hub bore is 64.1.
235/45-17 93W BRIDGESTONE 17X8.0 ALLOY +45mm offset 5-114.3 64.1hub bore 12X1.5 NUT 19MM HEAD
From my research i see one only problem between an altima and a TL.
64.1 hub is standard for the Acura TL.
Altima has...
66.1 hub Will this cause any sort of fitment/vibration problems?
Must I buy centric rings? Where can I purchase these?
Will they work?
By the way I have an 06 altima..
Old Apr 9, 2006 | 12:11 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
The hub is smaller on Hondas compared to the Nissan.
The wheel will not even fit over our hub without some machining done to the wheels. Sorry.
Old Apr 9, 2006 | 12:20 PM
drive4fun's Avatar
drive4fun
Thanks for the reply but I wouldn't be able to put the centric rings to take up 2mm of space?
ablaine
Nov 29, 2016 10:13 AM
Mattg350z
Oct 2, 2015 06:51 AM
