Do tire pressure monitors have to be reprogrammed?
Old Apr 18, 2006 | 07:53 AM
stevem's Avatar
stevem
Default Do tire pressure monitors have to be reprogrammed?
When changing from stock wheels to after market, assuming the monitors fit the new wheels correctly, and are in the exact same wheel placement, do the monitors need to be reprogrammed by Nissan?
Old Apr 18, 2006 | 08:22 AM
shanecrosby's Avatar
shanecrosby
My tire guages just have dashes next where the reading should be. Is this because I bought my car w/ aftermarket rims and am not sure it is reading the pressure? -19" Speedy's
Old Apr 18, 2006 | 08:24 AM
JokerDev's Avatar
JokerDev
I just changed mine, and did not need reprogramming
Old Apr 18, 2006 | 08:39 AM
stevem's Avatar
stevem
Thanks. That's what I thought, but even the Nissan dealer didn't know the answer!
Old Apr 18, 2006 | 08:42 AM
DavesZ#3's Avatar
DavesZ#3
That means that the tire pressure sensors are not installed on your aftermarket wheels. The original owner probably sold them with the OEM wheels.
Sometimes the sensors won't fit in an aftermarket wheel, it just depends on the wheel. There's a trick to adding the sensors to those wheels - banding. A lot more involved then the normal mounting method.
You can always pick up a set of used ones from the classifieds here on the board and get them installed then have the dealer re-register them to the computer onboard your Z then it will start displaying pressures again.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
