18x10 18x12 +10
Old Apr 19, 2006 | 07:19 AM
smellslikecurry's Avatar
smellslikecurry
Default 18x10 18x12 +10
Hey guys i have a question on some wheels...the sizes are 18x10 and 18x12 offset + 10 on both...is widebody the only option to make these fit or will some sick negative camber and beating the hell out of the fenders gnna make it?
Old Apr 19, 2006 | 07:48 AM
Motormouth's Avatar
Motormouth
wow. that is waay wide. I think you will need a WB kit.
a 10 & 12 +10? what brand are these?
Old Apr 19, 2006 | 08:08 AM
002-M-P's Avatar
002-M-P
Most people have to roll their fenders at the 18x10.5 +22 stage, so at 18x12 +10 would stick out another 31mm past that or 1.22 inches. So yeah...widebody I think would be the only way unless you could somehow flare you fenders, but that might look ugly.
Old Apr 19, 2006 | 10:14 AM
anotheraznguy's Avatar
anotheraznguy
NOT TRUE...
if you want...
18x10 +10
and 18x12 +10
ITS DOABLE
Ok so front's
so far i've ran as agressive as 18x9 +0 which is a 18x10 +12
Just get the cusco negative arm in front and crank the camber
make sure to run a 245 tire. my camber on the front is 3.5 degrees
For the rear
i ran as low as a 18x10 +0 which is a 18x12 +24
but if you stretch a 275 on that tire and get spc camber arms and max it out
you will be able to fit it not a problem.. my current camber on my car is 5 degrees negative.
So in review 245 on 10 275 on 12 will give you stretch
Roll fenders in rear
Get at least 3.5 and 5.0 camber
and you are good.
That is nothing..
right now i'm trying to fit..
19x10 -6
19x12 -20
try that on without wide fenders..
sales@czp
Sep 23, 2019 03:30 PM
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
lolsupfoo
Sep 9, 2015 12:57 PM
Aug 18, 2005 09:11 AM
Avalon Racing
Dec 14, 2004 09:29 PM
