18x10.5 +31 at all 4 corners????
Old Apr 30, 2006 | 11:46 PM
Z33Benny's Avatar
Z33Benny
Default 18x10.5 +31 at all 4 corners????
Does anyone know if this will work? Im looking at a used set of jdm wheels and wondering if i can pull this off? would i need spacers to make it possible?
I dont think the fronts would fit right, but what the hell.. i figured i would ask. lol.
Old May 1, 2006 | 04:41 AM
Kolia's Avatar
Kolia
I'm not sure.
But it should fit, depending on tire sizes.
I have 17x9.0 +30 up front on mine, with 255/40R17 tires. No spacers. The wider rim should not make a difference in the final position of the tire, only the offset counts.
I plan to test my 17x10.0 +30 rears with 275/40R17 on the front eventually.
Make sure the spokes actually clear the brake calipers.
Old May 1, 2006 | 02:34 PM
HXS's Avatar
HXS
10.5 up front = big no no
Old May 1, 2006 | 02:47 PM
jovasi's Avatar
jovasi
Agree 100%, no need for tires that wide up front.
Old May 1, 2006 | 03:03 PM
Kolia's Avatar
Kolia
Why not?
10.5 would be a bit of a stretch for a 275 tire, but still with in the suggested rim width.
Sport Compact Car's project 350Z runs 275/40R18 KDW on a +30mm offset wheel. It barely clears the suspension, but it's enough.
Old May 1, 2006 | 05:56 PM
Quamen's Avatar
Quamen
But again-Why do you need 275 up front? higher quality tires up front in a smaller diamter plus some wheel spacers (wider stance) should be able to handle what you can throw at the Z for the most part.
Old May 1, 2006 | 06:18 PM
mario60185's Avatar
mario60185
Chicago Realtor
10.5" rim is fine with a 275 series. 10.5" in front is a bad idea. Your steering will be affected, and general handling you dont want.
Old May 1, 2006 | 11:20 PM
Z33GRIP's Avatar
Z33GRIP
i believe you'll encounter understeer problems with that wide of a front.
Old May 2, 2006 | 03:53 AM
Kolia's Avatar
Kolia
That would depend on what he's running in the rear. If he goes 275 all around, he will have less understeer and maybe some oversteer.
Why would a 10.5" not be a good idea in the front? Appart for a slight increase in inertia, the tire would be a the same place with less side wall flex.
reno56
Interior
17
Nov 20, 2015 05:21 PM
RiujinZero
Sep 25, 2015 01:19 PM
ddegrande21
Sep 6, 2015 11:15 AM
