offset and tire question
Old May 15, 2006 | 06:02 PM
smellslikecurry's Avatar
smellslikecurry
Default offset and tire question
After spending countless hours researching offset and tire sizes and not finding anything...whats the fattest tire i can use on the front with a 18x9.5+12??? rolling and pulling is a given...i plan on lowering the car a good 1.5 soon so take that into consideration...thanksss again
Old May 15, 2006 | 06:22 PM
protocav's Avatar
protocav
that is an insane setup. a 9.5" wide rim is suited best to a 265 or 275 tire, but you may have to run a 255 to maximize the stretch.
Old May 16, 2006 | 10:19 AM
smellslikecurry
damn im going to try and fit 275s or 265s all around because i dont want a staggered tire size....
Old Jun 7, 2006 | 03:08 PM
smellslikecurry
any more ideas...the wheels arrive on saturday and i need to get some tires asap
Old Jun 7, 2006 | 05:27 PM
MoodDude's Avatar
MoodDude
Call tirerack and ask for Luke. He will help you get what you want.
Old Jun 7, 2006 | 07:10 PM
1nate7's Avatar
1nate7
That is a very aggressive offset. You are probably going to have to stretch some 245's or even 235's on the front. What is your rear width/offset going to be?
Old Jun 7, 2006 | 09:15 PM
protocav's Avatar
protocav
i have 9" front's with a 26 offset, and they rub the fender (granted my car is slammed and i have good camber). your setup is 20mm further out than mine. it will work if your car is not lowered, but it will look silly. i would run a 255 on it, it should stretch enough. i don't understand why you would run a 9.5" inch rim to put a 245 or 255 on it though? just to say you have a 9.5" front?
Old Jun 8, 2006 | 05:29 AM
2 low Z's Avatar
2 low Z
I have 19/9.5 with a + 19 offset in the front. I have 245/35s on it, a bit of a stretch but not all that bad with BFG and I' lowered about 1.7 or so with Tanabe NF210. Only rubs with the wheel turned and going up a steep incline. I haven't modified my front fenders in any way.
I'm actually consdering 265/30, but that may be pushing it.
Old Jun 8, 2006 | 05:32 AM
sq40's Avatar
sq40
Food for thought;
The car is supposed to have a staggered Height because of the VDC/TCS system.
Old Jun 8, 2006 | 12:52 PM
smellslikecurry
thanks guys...wheel size is the same all around...my cars stock height now with coils on the way...lemme slap on some cheap 255s see what theyre like then shred em up then move my way up...its all trial and error i guess
Old Jun 9, 2006 | 06:57 PM
smellslikecurry
any other recomendations on what size tire i should run?
Old Jun 9, 2006 | 07:07 PM
m1james@bellsou's Avatar
m1james@bellsou
trial and error if you will, but straying too far from original circumfrence will wreak havoc on your tracion/skid control systems as pointed out. Handling will be unpredictable too.
Race cars vary tire pressure by less than 1 PSI to change handling dynamics and your change is much more radical than that. Unless your depth of knowledge is huge, it could be an expensive trial and error period.
A reputable tire store can help. They will have circumference data by tire brand and size so you can minimize the risk. I've seen it on this forum also if you hunt a bit.
Good luck!
Old Jun 9, 2006 | 08:37 PM
-EL's Avatar
-EL
Originally Posted by sq40
Food for thought;
I don't think traction control cares much about the different wheel diameters front to back, just VDC. I mounted 265/40R18s on all four corners and the car doesn't complain at me, but I have an 04 Enthusiast, no VDC for me.
-E
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
