Wheel spacers
Old May 19, 2006 | 06:10 AM
Dubai's Avatar
Dubai
Arrow Wheel spacers
I have 19" wheels F 9.5 offset +33 with a 245/35/19 tires, R 10.5 offset +34 with a 275/35/19 tires.
What wheel spacers size for front and rear should I use? brand?
all I want is more agressive look without rubbing issue.
comment?
Old May 19, 2006 | 09:10 AM
DmanG281's Avatar
DmanG281
I would probably stay within 10-15mm for a wheel spacer. A 10 would be sufficient. I had a 7 mm spacer made and it caused rubbing on my +24 19/11 with 295/35.
Old May 19, 2006 | 09:15 AM
Dubai's Avatar
Dubai
Do you think I'll have rubbing using 15mm with 275/35 tires? or should I stick with the 10mm!
Old May 19, 2006 | 09:30 AM
RNL323's Avatar
RNL323
Mod My Ride
With "R 10.5 offset +34 with a 275/35/19 tires" ....
Safest bet would be 10mm spacer to get you to +24. If you go 15mm spacer, you'll be at +19 and will most likely rub.
Old May 19, 2006 | 10:16 AM
Dubai's Avatar
Dubai
Thanks for the input man. what about front, should I also go 10mm?
Old May 20, 2006 | 05:45 AM
Dubai's Avatar
Dubai
bump anyone..?
Old May 20, 2006 | 07:19 AM
mario60185's Avatar
mario60185
Chicago Realtor
I think front 10mm would be good also.
Old May 20, 2006 | 07:37 AM
Dubai's Avatar
Dubai
^^ great. whats the best brand to get for 10mm, H&R? and where can I buy it from?
cheers
Old May 21, 2006 | 02:05 AM
jinsei888's Avatar
jinsei888
even if you did, you should just get the fenders rolled for the sake of BEING able to attain that better looking offset!
Old May 21, 2006 | 02:07 AM
Z33Benny's Avatar
Z33Benny
ive got four 15mm project kics spacer brand new in box if your looking for some. never used. $220 shipped
Obadabot
Jun 18, 2023 11:31 PM
