Will these Mustang SVT Cobra R rims fit?
Old May 21, 2006 | 05:20 AM
TheCajunStyle's Avatar
TheCajunStyle
Default Will these Mustang SVT Cobra R rims fit?
I'm trying to find two rims (for drag racing)...The requirements were that they be 17x9, lightweight, fairly inexpensive, and fit on my '05 Z (non-brembo).
Could you tell me if these will fit?
Link
Could someone explain what Summit Racng means by "backspacing" ?
Old May 21, 2006 | 05:31 AM
TheCajunStyle
ok--backspacing is another way of describing "off set" ...
still would like to know if these rims will suffice
Old May 21, 2006 | 03:39 PM
Mustang bolt pattern: 5 x 4.5 in.(114.3mm)
350Z Bolt Pattern: 5/114.3
Yes the wheels will bolt-up. You mentioned lightweight. All I see is the word cast. I assume that these wheels are 20 pounds plus.
Old May 21, 2006 | 04:31 PM
plumpzz's Avatar
plumpzz
rx7 stock rims are probably ab etter choice. They're not only lighter but being 17' they also have a few more choices of wheels. Im not sure if those are 17. Rx7 wheels are 13 or 16 lbs, depending on the year.
Old May 21, 2006 | 07:43 PM
ouch1011's Avatar
ouch1011
Are you talking about 93-95 RX7 wheels? If so, those are 16x8 with a 50mm offset Bolt pattern is the same, 5x114.3
Old May 21, 2006 | 07:53 PM
plumpzz's Avatar
plumpzz
Even better, more slick choices and less radius (which is always better)
Old May 23, 2006 | 12:27 PM
JimRHIT's Avatar
JimRHIT
Old Pontiac 16" (Gran Prix GrandAm) wheels work great for slicks/DRs as well. If you have Brembos you'll need a 15mm spacer
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
Alexreyes
Sep 30, 2015 11:30 PM
