::NISMO Wheels Thread::
Old Mar 21, 2011 | 01:11 PM
  #1081
dtsj350z's Avatar
dtsj350z
I put back the nismo last week, and happier. haha. I had te37 f-zeros and then work meister (matte spoke and gloss black lip).
Old Mar 24, 2011 | 09:24 PM
  #1082
mike_eee's Avatar
mike_eee
Default Nismo LMGT4 Advice needed
Hello Folks today I picked up a set of used set of Nismo LMGT4 18x8.5 +25 Front 18x9.5 +30 Rear
looks like they Powder coated it and has been used ..so there are some defects like road tar or some black stuff here and there on the wheels which is not noticeable and two curb rashes...the tires are bald so I am replacing them.
the sale was local and the price was not bad I jumped on it...u have to love crag list adds...its where once i snagged a whole OEM nismo v3 kit .
Now I do have stock 35 anniversary wheels with these tire sizes
front:Tire: 225/45/18
rear:245/45/18
can I use these tires on these Nismo wheels that I just bought?? any issues?
can I also transfer the stock TPMS to the new NISMO wheels??
Mike
Attached Thumbnails ::NISMO Wheels Thread::-nismobig2.jpg   ::NISMO Wheels Thread::-dsc06791.jpg   ::NISMO Wheels Thread::-dsc06790.jpg
Old Mar 24, 2011 | 09:37 PM
  #1083
Voboy's Avatar
Voboy
rear:245/45/18
Mike
Yes and yes to both questions. But tires are a little thin to be swapped over but that is just my preference.
Old Mar 24, 2011 | 10:07 PM
  #1084
Mcutali's Avatar
Mcutali
Question re
voboy what do you suggest tire wise?
Old Mar 24, 2011 | 10:20 PM
  #1085
terrasmak's Avatar
245/40 and 275/40 is standard tire fitment for your wheels.
Old Mar 25, 2011 | 01:36 AM
  #1086
r_seng's Avatar
r_seng
Old Mar 25, 2011 | 03:21 AM
  #1087
Good looking wheels. Yes you can run your F225 R245 tires. When it comes time to replace the tires you can go wider.
Old Mar 25, 2011 | 06:53 AM
  #1088
Kuhan's Avatar
Kuhan
What year is your 350Z?
If you have 03-05 (or 03-06?), then it has the tire pressure readings on your dash, so make sure you move the tpms from the old wheel to the new ones accordingly.
If you have 06-09 (or 07-09?), then it doesn't matter since it only shows low tire pressure warning only.
Also you can use your stock tires on the new wheels, but I'd go with new tires 245/40 and 275/40 and keep the stock tires with wheels for spare use.
Old Mar 25, 2011 | 09:06 AM
  #1089
Voboy's Avatar
Voboy
There are a number of combinations you could run on your staggered wheel sizes like stated above, but my preference is 255/40/18 front and 275/40/18 rear. I prefer trying to have a larger front tire up front and minimizing the width difference between front and rear to reduce understeer/getting a more neutral feeling.
Old Mar 25, 2011 | 12:02 PM
  #1090
terrasmak's Avatar
I actually prefure and run the 255/40 275/40 combo, but....... i run a wider wheel up front than the 8.5 the OP has.
Old Mar 25, 2011 | 05:55 PM
  #1091
ihellaheart350z's Avatar
ihellaheart350z
When i first got my LMGT4's they had the stock F225/R245 setup. (same wheel specs as OP) and after i switched them out to F245/R275 i noticed a huge improvement! Definitely go with the wider tires, you won't regret it!
Old Mar 25, 2011 | 09:31 PM
  #1092
Voboy's Avatar
Voboy
Yea that's usually the case, but the 255 is within the minimum spec for 8.5 rim width so why not. Depending on the tire it might be a little fat in front but it's still extra grip!
Old Mar 27, 2011 | 01:01 PM
  #1093
mike_eee's Avatar
mike_eee
Thanks guys for all your inputs...for now Iam going to fit the stock tires from the wheels i have now and later switch to the recommended ones.
Now will the TPMS from my stock wheels fit in these wheels directly?? valve stem issues etc??
also is there any specific lug nut that you could recommend .
thanks
Mike
Old Mar 28, 2011 | 02:16 PM
  #1094
Jamaica2G's Avatar
Jamaica2G
Originally Posted by mgrotel
what happened to your spacer? ive done many canyon runs with a 20/25 combo with my oem 19" rays with no problems. did you have them torqued correctly?
Yah. I drive around with a torque wrench in my car at all times! Yes, I had them torques correctly. I honestly don't know why it happened, but it started making noises - basically a clicking noise at slow or high speed while turning. It's as if one of the lugs was loose or something. I took them off and swapped sides and the same spacer is the one with the problem. So, I quit using them :-(
Better safe than sorry.
Adrian
Old Mar 28, 2011 | 02:53 PM
  #1095
mgrotel's Avatar
mgrotel
Loose lug nuts will cause a clicking noise
Old Apr 4, 2011 | 04:41 AM
  #1096
Jamaica2G's Avatar
Jamaica2G
It wasn't the lug nuts themselves... I think the problem lies in the lugs that are in the spacer.
I took them off (no click)
Put them back on (click)
Took them off (no click)
Swapped sides (click on the opposite side)
Every time I had them torqued to spec.
Called and emailed ichibaUSA... No response...
Old Apr 4, 2011 | 06:10 AM
  #1097
mgrotel's Avatar
mgrotel
hmmm, thats weird, maybe the stud in the spacer was not in tight enough. multiple times ive had loose lug nuts and they clicked, tightened them up and the click went away. something wasnt tight
Old Apr 4, 2011 | 09:35 AM
  #1098
ZPirate's Avatar
ZPirate
I added some vinyl "Nismo" lettering to my 370Z Nismo wheels.
Old Apr 6, 2011 | 05:59 PM
  #1099
ihellaheart350z
the TPMS will work, buut, the TPMS for the Z is super sensitive and easily damaged from what I've read. My TPMS started acting up on me saying psi was low when it was not..Big O Tires has a TPMS refurb kit for like $15 per tire, they pretty much just replace the O rings from what I understand, I had them do that when I got new tires and since then my TPMS works great.
Old Apr 16, 2011 | 07:49 PM
  #1100
dragon11689's Avatar
dragon11689
Hey guys! Awesome wheels by the way. I have the nismo setup in 18X9.5 front to back. Tire set up is 275/35/18 front and 275/40/18 rear. I have 2 questions. Do any of you guys have advice on adverse effects to front suspension going this wide in the front. Also, what sizes do you recommend for wheel spacers front to back in order to stay flush with the body. I was leaning towards front 15mm and rear 25mm. Any suggestions? Thanks in advance.
