::NISMO Wheels Thread::
Old May 15, 2011 | 10:53 AM
  #1121
Waiz's Avatar
Waiz
Wheels look nice, but you need a drop badly.
If you run spacers you will need to roll those rear fenders depending in the size of spacer. It's not difficult to have them rolled, so don't worry about that.
Old May 17, 2011 | 08:39 AM
  #1122
370zGatorman's Avatar
370zGatorman
You can check my gallery as I have the 18's. I am lowered on the Eibach Pro springs and have 15mm spacers in the front and 25mm in the rear. I tried 20mm in the front but was rubbing A LOT. Also, my rear fenders ARE rolled.
Old May 18, 2011 | 02:56 AM
  #1123
raiyan84's Avatar
raiyan84
im running the same wheels and sizes exept in 19s and 275/35 rear and 245/35 front worked best for me for the next time you get tires, i think 40 would be too high a sidewall and would rub more
Old May 18, 2011 | 02:59 AM
  #1124
raiyan84's Avatar
raiyan84
im also on a 1 and a half inch drop and have no rub with 25mm spacers in the rear, although i did roll my fenders
Old May 22, 2011 | 10:08 PM
  #1125
mike_eee's Avatar
mike_eee
guys,
thanks for all the comments..if u notice the front..with V3 the car is super low in front with lip..i like to keep that height and not lower, cause it will scrape on every driveway and bump... rear yes I can lower and add spacers or just add spacers.. please advice
Mike
Old May 22, 2011 | 10:59 PM
  #1126
BrandonHeat's Avatar
BrandonHeat
Originally Posted by mike_eee
guys,
Mike
Not true about scraping every driveway etc. If you don't rush going into driveways like you're running from someone you'll be fine. A 1" drop won't murder your bumper at all. But if you just run spacers that will help you out, if you don't want a drop. I run 20mm front 25mm rear. Get spacers first I say.
Old May 22, 2011 | 11:09 PM
  #1127
VQpoweredZ's Avatar
VQpoweredZ
This has the potential to be a really nice setup. I love the wheels.
Let me try and help you out. I'm sure an inch drop in the front wouldn't make your car that much lower. The inch will make you like your car that much more, trust me. You just have to be careful when you go in and out of places to go slower and at a bigger angle. Lower the front an inch, and lower the rear accordingly. Look into some coilovers or some springs that vendors have available and compare the drops they will give you.
245/40 and 275/40 is standard tire fitment for your wheels.
Use these tire sizes. The tire sizes you are using now is making your car have more wheel gap and it looks a little odd.
As Wais says, get your rear fenders rolled before you drop the car. Make sure you go to someone who is reputable and has an eastwood fender roller with a heat gun.
All good advice in this thread and you should be able to achieve the look you want if you follow some simple guidelines. This is what I would do...
1. Buy 245/40/18 and 275/40/18 tires
2. Purchase either coilovers or springs with a rear camber kit.
3. Get your rear fenders rolled
4. Install and enjoy!
Old May 23, 2011 | 07:46 PM
  #1128
kiwi4784's Avatar
kiwi4784
Originally Posted by scenehouser
can anyone confirm that the lmgt4 in 19x10.5 +30 have a lip?
a picture would be awesome.
hi ill take a picture of my 19 x 10.5 when it arrives from japan.
how do you guys think 19 x 8.5 f 19 x 10.5 r will look?
lmgt4
Old May 23, 2011 | 07:48 PM
  #1129
kiwi4784's Avatar
kiwi4784
suggestions for tires?
suggestions for lug nuts both would be awesome.
thanks
Old May 23, 2011 | 09:07 PM
  #1130
Waiz's Avatar
Waiz
245-35-19 & 285-35-19
The wheels should already come with Nismo lugs (if you bought the wheels new) otherwise it all depends on your budget.
Old May 24, 2011 | 04:29 PM
  #1131
kiwi4784's Avatar
kiwi4784
Nissan has discontinued the rim.
so i have bought these from japan i believe they come from rays.
Old May 25, 2011 | 08:33 AM
  #1132
kiwi4784's Avatar
kiwi4784
My rear will be 19 x 10.5 +30 will this require a roll?
Old May 25, 2011 | 08:35 AM
  #1133
kiwi4784's Avatar
kiwi4784
Sorry they come dirrect from rays factory to new erra
Old May 25, 2011 | 10:36 AM
  #1134
Waiz's Avatar
Waiz
+30 on stock suspension will not require a roll.
Old May 25, 2011 | 10:57 AM
  #1135
angelo350z's Avatar
angelo350z
^^ Correct. The 19x10.5 +30 will have a fatter lip and won't require a roll. I tried to get these last year in silver but only bronze was available. Post pics!
Old May 27, 2011 | 06:55 PM
  #1136
silents1ick's Avatar
silents1ick
Originally Posted by BOOCKER
Hey dude, u need some kind of spacer to fit the nismos 370z wheels, to clear the brembo brakes?
na it clears the BBK as wells as stock brembos... only problem i had was front fitment..couldnt make it fit in the front without spacers because inner part of the rim would rub on the suspension.
Old Jun 6, 2011 | 07:13 AM
  #1137
silents1ick
here are some updated pics woth 5mm spacer.
Thanks a lot to MIKE the powdercoater for the nismo stickers...
Old Jun 6, 2011 | 08:09 AM
  #1138
ImWeeZzel's Avatar
ImWeeZzel
your car its coming along nicely, keep its updated when you paint your front bumper
Old Jun 6, 2011 | 11:02 AM
  #1139
chrisjersey06's Avatar
chrisjersey06
Old Jun 6, 2011 | 11:29 AM
  #1140
VQpoweredZ's Avatar
VQpoweredZ
^^Oh wow. I'm so jelly right now!
Looks fantastic. Need moar shots .
