::NISMO Wheels Thread::
Old Aug 10, 2011 | 05:06 AM
  #1221
370zGatorman's Avatar
370zGatorman
From what I've read you should stick with the 40 series. I haven't tried 45's on mine but it's not the recommended series.
Old Aug 10, 2011 | 12:33 PM
  #1222
mike_eee's Avatar
mike_eee
can i use? 255-40ZR\18 for the front instead,
i will have 275/40/18 for back and 255/40/18 for front..will this combo work good for performance for LMGT4?
Mike
Old Aug 10, 2011 | 12:56 PM
  #1223
terrasmak's Avatar
255/40-18 works great as a front tire as mentioned in the first few posts.
Old Aug 10, 2011 | 12:59 PM
  #1224
mike_eee's Avatar
mike_eee
that's great news...so I am going with 255/275/40/18 combo ..
I am going to use 15mm spacer in front and 20 mm spacer in the back.. and also gonna roll my rear fenders...do i need to roll my front fenders too???
Mike
Old Aug 10, 2011 | 02:10 PM
  #1225
terrasmak's Avatar
You shouldn't , really nothing to roll.
Old Aug 10, 2011 | 03:48 PM
  #1226
Waiz's Avatar
Waiz
Originally Posted by mike_eee
hello guys, finally I got some parts
rear tires 275/40/18
spacer 15 mm and 20 mm ichiba v2
tein and tokico springs and shocks
now for the front...can i get 245/45/18 instead of 245/40/18 or should i stick with 40/18??
mike
FYI, for the sake of keeping things organized your original thread has been merged with this one.
Really this is where you should have posted all of your questions since this is the thread for the LMGT4's..
Old Aug 10, 2011 | 05:27 PM
  #1227
Ruthless18x's Avatar
Ruthless18x
I had to roll my rears with similar spacers and 275's...but I'm pretty low.
Old Aug 10, 2011 | 05:32 PM
  #1228
Waiz's Avatar
Waiz
Does your front rub? Mine does but I want to be herrafrush so I leave it
Old Aug 10, 2011 | 06:07 PM
  #1229
Ruthless18x
A little on full turns lol
Hell yeah waizzz, being flush on monoblocks is gangsta!
Old Aug 11, 2011 | 10:57 PM
  #1230
mike_eee's Avatar
mike_eee
With 255/275/40/18 combo will my TCS/VDC be happy??
Mike
Old Aug 11, 2011 | 11:37 PM
  #1231
Waiz's Avatar
Waiz
Mike
Yes, that's totally fine..
Old Aug 21, 2011 | 12:20 PM
  #1232
mike_eee's Avatar
mike_eee
ok tire and wheel guru's I need your help seriously..I did what was adviced to me and now my Z handles/drives horribly..something is wrong. the acceleration sucks!! no more nimble, feels heavy and I need to develop huge biceps to turn the steering anymore.
Now let me explain the history..
I have the standard offset LMGT4
before have 255/45/18 for back and 225/45/18 for front... every one said they are narrow wheels and i should go wider so I did the following.
first I got my fender rolled for just a security no harm
got for rear 275/40/18 r
and for front 255/40 /18 r
for front i used 15mm ichiba spacer and for back i have 20 mm ichiba spacer
the car is not lowered yet ...will be lowered next month on tokico d spec and tein s tech springs.
now the car as is on new tires and spacers handles like a tank..lost acceleration and steering is super heavy.. what did i do wrong..oh note the front wheel has slight cupping issue ..was on my M3 but i dont think it will affect this bad..should i got 245/40/18 on front instead of 255/40/18.
Also do look at the attached pics..these wheels do stick out..almost make me want to delete spacers.
please advice
Mike
Attached Thumbnails ::NISMO Wheels Thread::-dsc06856.jpg   ::NISMO Wheels Thread::-dsc06857.jpg   ::NISMO Wheels Thread::-dsc06858.jpg   ::NISMO Wheels Thread::-dsc06859.jpg   ::NISMO Wheels Thread::-dsc06861.jpg
Old Aug 21, 2011 | 01:27 PM
  #1233
Ruthless18x
^ that wheel tire setup should not hinder performance. Something else must be wrong.
Old Aug 21, 2011 | 01:33 PM
  #1234
mike_eee's Avatar
mike_eee
does wider tire do affect acceleration?? i went from 225 to 255 in front..i can feel in my butt dyno...also my front tires has the cupping issue from my M3 so i guess it might be the culprit..i think i should invest in new tires .
Old Aug 21, 2011 | 03:05 PM
  #1235
Waiz's Avatar
Waiz
I think your butt dyno needs a recalibration
Old Aug 22, 2011 | 04:57 PM
  #1236
mgrotel's Avatar
mgrotel
What tires? Only thing I can think of is the tires are really heavy run flats. I have same wheels, offsets, and tire sizes, only difference is that I use 20mm spacer on the front and 15mm on the rear. As far as the cupping issue, go get an alignment, should be able to remedy that since you aren't lowered
Old Aug 22, 2011 | 05:24 PM
  #1237
mike_eee's Avatar
mike_eee
the tires i am using are Pirelli PZero Rosso , cupping is an issue mainly cause if u have bad suspension and so caused by tire bouncing...the front tires i used was my old M3 which had bad suspension, so the cupping was not caused by my z..
I am going to lower the car soon and then change the front tires to better ones and get an alignment after the springs are set.
Old Sep 7, 2011 | 05:40 AM
  #1238
ImWeeZzel's Avatar
ImWeeZzel
noob question, will the tmps fit on our wheels? Id like to install them because of the annoying blinking light. Thanks guys
Old Sep 7, 2011 | 05:42 AM
  #1239
370zGatorman
Yes, I have them on mine.
Old Sep 7, 2011 | 05:46 AM
  #1240
SDGenius's Avatar
SDGenius
great thread, i'll post in here once i have some better pictures
