::NISMO Wheels Thread::
Old Aug 6, 2011 | 11:34 PM
  #1201
Waiz's Avatar
Waiz
Nice! I think I still have a few of those too
Old Aug 7, 2011 | 12:58 PM
  #1202
oyvino's Avatar
oyvino
Default Nismo lmgt4 offsets plz help!
Hello!
Know that this probably have been answered before, but i can't
find out what's the best fitment without using spacers!
Thought about going for 8,5x19" +25 on fronts and 9,5x19" +20 rear
Like the 10,5x19" rear wheels though, but not sure what will fit without
rolling fenders or running negative camber, or if i have to go 9,5x19" up front!
Basicly what wheel offsets/tire sizes would you reccomend?
My car is stock ride height!
All help would be much appreciated!
Old Aug 7, 2011 | 01:02 PM
  #1203
huyrua's Avatar
huyrua
What size tires are you planning to use?
Old Aug 7, 2011 | 01:07 PM
  #1204
oyvino's Avatar
oyvino
Default nismo lmgt4
Thought about the "standard" 245/35/19 fr & 275/35/19 rear
Old Aug 7, 2011 | 01:29 PM
  #1205
terrasmak's Avatar
10.5 will fit in the rear without a roll or camber. As you space it ou from +30 and get more agresssive you will start to run and need a roll. Just do a roll in the rear and your all set.
9.5 up front fits and does not rub with the proper offset. Idealy if you don't want to worry about rubbing just get something around +25 front and rear.
Old Aug 7, 2011 | 01:37 PM
  #1206
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Aug 7, 2011 | 01:51 PM
  #1207
oyvino's Avatar
oyvino
Ok, so if I go with a 8,5"x19" + 25 wheel in front wrapped in 245/35/19 tires
and 9,5"x19" rear with 275/35/19 tires, i'll be ok?
Will these offsets be pretty flush with the fenders ?
Do not want the wheels to be outside the fender, just alot more aggressive than
the stock 18" rays!
Can get the wheels in: 8,5x19 +25 , 9,5x19 in +12 +20 +23 +25 and 10,5x19 in +15 +30
If anyone got a better suggestion!
Old Aug 7, 2011 | 01:56 PM
  #1208
terrasmak's Avatar
the stock 18" rays!
9.5 +25 front and 10.5 +30 rear. Then run a 255/35-19 up front with a 285/35 rear.
Old Aug 7, 2011 | 02:50 PM
  #1209
NissanZ03's Avatar
NissanZ03
^ What he said. They're not too aggressive you should be ok
Old Aug 7, 2011 | 03:09 PM
  #1210
oyvino's Avatar
oyvino
Thanks!
Does anyone have a picture of how that would look on a standard height car?
Sorry for nagging, but i must get it right on the first try, since i'm ordering the wheels
from UK!
Old Aug 7, 2011 | 03:28 PM
  #1211
Czarrr's Avatar
Czarrr
19x9.5 and 19x10.5 with a +25 offset.
+22 would be better.
You'll be fine on stock height.
You won't get flush without rolling the fenders.
+12 is my recommendation that isn't too aggressive.
Old Aug 7, 2011 | 06:46 PM
  #1212
Waiz's Avatar
Waiz
Hello!
Threads merged..
Search is your friend, we already have a gigantic thread for these wheels that would have answered your question.
Old Aug 8, 2011 | 01:21 AM
  #1213
oyvino's Avatar
oyvino
Yes, i knew about this thread and have read though all the pages!
Just weren't sure about what was using spacers,rolling fenders, only on lowered cars
and so on! Anyhow thanks for the help guys!
Old Aug 8, 2011 | 07:52 AM
  #1214
BOOCKER's Avatar
BOOCKER
does any body knows where can i find one front wheel and one rear wheel from a nismo 370z? i dont cake if they r used...
pls LMK
Old Aug 8, 2011 | 07:57 AM
  #1215
Ruthless18x's Avatar
Ruthless18x
pls LMK
Mmm...cake.
Old Aug 8, 2011 | 09:47 AM
  #1216
Waiz's Avatar
Waiz
I know there are several posts on that topic, I must have 4-5 posts alone on it.
Do you have access to the +12 versions in the UK?
pls LMK
Your best bet is the dealer, I don't know anyone who is selling one front and one rear.
Did you damage your two wheels beyond repair?
Old Aug 8, 2011 | 01:45 PM
  #1217
BOOCKER's Avatar
BOOCKER
Well, i got them in a junkyard, i dont know why they have just 2 of them.
Old Aug 8, 2011 | 01:48 PM
  #1218
Waiz's Avatar
Waiz
It will be pretty hard to find one of each used again. I would create a WTB in the vendors classified and someone might be able to order them for you at a reasonable price.
Old Aug 8, 2011 | 08:14 PM
  #1219
BOOCKER's Avatar
BOOCKER
yes, is hard to find them, and i already created it, well, i hope some day find them cos i love those wheels...
Old Aug 10, 2011 | 12:58 AM
  #1220
mike_eee's Avatar
mike_eee
hello guys, finally I got some parts
rear tires 275/40/18
spacer 15 mm and 20 mm ichiba v2
tein and tokico springs and shocks
now for the front...can i get 245/45/18 instead of 245/40/18 or should i stick with 40/18??
mike
