::NISMO Wheels Thread::
Old Jun 11, 2012 | 10:26 PM
  #1521
mgrotel's Avatar
mgrotel
^on the wheels?
just the standard 18x9.5 rear and 18x8.5 front, used to be gold but pc'd black, the offsets escape me at the moment, but they are the standard 18s, whatever those are. 15mm spacers rear and 20mm front. Rear tires are 275/40/18 and fronts are 245/40/18.
lowered on stance gr+pro coils.
Old Jun 12, 2012 | 07:10 PM
  #1522
Jamaica2G's Avatar
Jamaica2G
Originally Posted by Jamaica2G
More red wheel photos NOW!!!
Found Em!
Old Jun 12, 2012 | 07:38 PM
  #1523
DBTre50z's Avatar
DBTre50z
^ Not a fan of that particular red but fo sho the nismo 370's are sex. Id like to see them in black or a dark bronze color
Old Jun 12, 2012 | 07:42 PM
  #1524
-Trav-'s Avatar
-Trav-
I dont see why theres so much hype surrounding these wheels. To me the style doesnt fit the 350z whatsoever. I apologize if I come off rude, but I just dont get it.
350z with LMGT4s on the other hand, now thats a match made in heaven.
Old Jun 12, 2012 | 07:48 PM
  #1525
mattleegee's Avatar
mattleegee
kind of liking the 370 wheels on the 350... not red on silver though... should have went blue!
+1 LMGT4's want!
I have been shopping for rims for the last two weeks, Varstoens(te37 reps), RPF01, the usual's, but i keep coming back to Rays/Nissan wheels
Old Jun 13, 2012 | 06:11 AM
  #1526
Waiz's Avatar
Waiz
To each his own, I wouldn't have went with red but the sizing of the 370Z NISMO's and the affordablility are pretty hard to beat
+1 LMGT4's want!
You can't go wrong with LMGT-4's!
Old Jun 13, 2012 | 11:30 AM
  #1527
DBTre50z's Avatar
DBTre50z
I know why you say they dont flow with the car and its because the wheels are sharper looking where as the 350z has softer/rounder body lines. I saw a picture of them on a 350z powder coated black with a subtle bodykit and drop and they just flowed very nicely. I had a thing for the lmgt4s for a while but now I'd just rather a set of GT/07+ Nismo wheels
Old Jun 13, 2012 | 01:19 PM
  #1528
08z206's Avatar
08z206
I feel what you're saying but I just didnt want to blend in with the rest of the 350s "dumped on same style volks , te37s" etc wanted somthing more unique plus I still have the original silver color on the 370 nismos thats right, I can peel off the red anytime i want.
Old Jun 14, 2012 | 04:44 AM
  #1529
angelo350z's Avatar
angelo350z
^^ I think your red wheels look great on the car. The red pillar ... not so much though.
Old Jun 14, 2012 | 07:44 AM
  #1530
08z206's Avatar
08z206
Yaa thats been off lol ill post new pics in a couple weeks once i get my nismo v3 front bumper
Old Jul 13, 2012 | 09:18 PM
  #1531
GunslingerG34's Avatar
GunslingerG34
Question NISMO wheels???
I recently purchased a 2004 350Z Roadster (Enthusiast in Pikes Peak White with a navy blue top and auto tran) and I absolutely LOVE this car!!! I have been looking at some different wheels and I REALLY like the NISMO LMZ5 wheels (19"x10" with 245/40/19 (front) and 275/35/19 (rear) tires. But I have a few questions, if anyone can give me some advice here:
For my car, would I want the +47mm or +30mm offset?
If any of you have run these wheels, did you encounter any clearance issues --- particularly if you also run the NISMO suspension kit (lowered 0.6")?
And last but not least, Will this combo change my speedometer calibration, and if so how do I get it corrected.
All input/advice will be GREATLY appreciated!!!!!!
Old Jul 13, 2012 | 10:27 PM
  #1532
ZS14RR's Avatar
ZS14RR
Neither of those offsets. You should be looking into the +20 or less
Old Jul 13, 2012 | 10:56 PM
  #1533
Waiz's Avatar
Waiz
Welcome to the forum, please search before creating future threads as we already have a massive thread for NISMO wheels.
Regarding offset you want to refer to this post within the TOP 100 FAQ:
https://my350z.com/forum/2003-2009-n...questions.html
https://my350z.com/forum/2487452-post8.html
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
Old Jul 17, 2012 | 01:20 AM
  #1534
GunslingerG34
Hmmmm............this just keeps getting more confusing the more I research!
It sounds like the LMZ5's shouldn't work, due to the offset (+47mm front and +30mm rear) --- but I keep seeing pictures of 350Z's with these wheels (or some that look virtually identical) on them!!! I've read and read and read, but still can't find a clear answer anywhere as to whether or not these 370Z wheels will work on my 350Z. I also wouldn't mind a set of LMGT-4's, but good luck finding any!!! The LMZ5's are relatively inexpensive though and easy to find. Did NISMO/Ray's make this wheel in multiple offsets (other than the 2 I listed)??? Sorry to sound like such a newbie, but I AM new to dealing with wheels with so many variances.
Old Jul 17, 2012 | 04:55 PM
  #1535
Z-speed33's Avatar
Z-speed33
Heres some pictures of my Limited Black LMGT4's in a 19x9.5 and 19x10.5.
Old Jul 17, 2012 | 11:20 PM
  #1536
Waiz's Avatar
Waiz
Yes they work, they just aren't the ideal specs but spacers can fix that.
There is already someone with these wheels in this thread:
https://my350z.com/forum/9672469-post1446.html
I do not see them being a problem with your Brembos especially if you add spacers to them.
What are your offsets?
Old Jul 18, 2012 | 04:57 PM
  #1537
GunslingerG34
Thumbs up
Thanks for the info/help guys!!! I PM'ed Touge-drifter about his experience with the LMZ5's on a 350Z. he was VERY helpful and was able to tell me exactly what I needed to know. So, I went and bought the set of wheels earlier today (set of 4 brand new in the boxes for $800 ), now I just have to come up with center caps, lug nuts, and a set of pressure sensors (and a pair of 15mm spacers) and I'll be good-to-go in the wheel department. I'll start on the suspension and brakes (something I know a lot more about than wheels!) next.
I can already tell that even though I am taking a relatively conservative approach, I need to plan on being "car-poor" for a while because every spare penny I can scrounge up will go into my Z. I don't see how younger folks do it, lol. I'll attempt to post some pics once I have the new wheels on the car!!
Old Jul 18, 2012 | 05:14 PM
  #1538
GunslingerG34
They both look WAY better than 99% of the aftermarket wheels out there!! Actually, I think I like the LMZ5's quite a bit better than the everyone-has-them, bellybutton LMGT4's (which are very good wheels, but it seems that half the cars on this forum are running either them or cheaper knock-offs).
Touge-drifter has a set of LMZ5's on his 350 that look awesome IMHO. Now the other set of 370Z NISMO's pictured (I can't remember the number for them) look even better, but I haven't seen any for sale yet so I don't know what their prices are running.
  #1539
GunslingerG34
Well damn. I just realized I replied to a 2-year-old thread!! My bad!!!
Old Jul 18, 2012 | 11:48 PM
  #1540
GunslingerG34
Also, does anyone here have a clue what center caps I need for the LMZ5's?? Hopefully someone out there can tell me, because I've been searching/googling for an answer for the last 4+ hours and cannot find an answer anywhere.
