FRONT = 19x8.5 / REAR = 19.9.5 suggestions
Old May 25, 2006 | 03:50 PM
IslandZavage's Avatar
IslandZavage
Default FRONT = 19x8.5 / REAR = 19.9.5 suggestions
I bought some new wheels and am looking for sizes now.. The wheels are as follows"
FRONT = 19x8.5 (20mm offset)
REAR = 19.9.5 (20mm offset)
Im looking to lower the car an 1 inch and not have to roll the fenders... Anyone have any suggestions or pix to demo???? Im thinking 245 or 255/35 for the front and 275 or 285 rear.... Also, will this give me any slip light issues? if you have a similar setup pix would be appreciated.......
Old May 25, 2006 | 05:28 PM
momo 350z's Avatar
momo 350z
just to let you know i have the same set-up but mine are 22mm offset and my car is lowerd 1.5 in the front and 1.75 in the rear..with your rims you can only fit a 235 35 or lower series profile and a 275 in the rear,,a 245 series tires wont stretch on a 8.5" rim the guys at ntb tried and it wouldnt work..
Old May 25, 2006 | 05:59 PM
Mach V Dan's Avatar
Mach V Dan
Huh? That's wrong; you can easily get a 245 or even a 255 on an 8.5" rim. The NTB people must suck. (255 is about as fat as I would go on an 8.5", though.)
Get a real performance tire install place to take care of you.
--Dan
Mach V
Fast350.com
Old May 25, 2006 | 06:00 PM
LvntheZ's Avatar
LvntheZ
i have 245 on a 8.5 seems perfect to me
Old May 26, 2006 | 04:27 AM
IslandZavage
I think it may just be that shop. I did a search and found that 245/275 are almost the norm for the setup i have. So im more curious about a 255/285 setup.
Old May 26, 2006 | 05:25 AM
jcs4's Avatar
jcs4
245mm is the perfect tire for a 8.5 wide wheel. Im running 245 and 285/35/19 and no issues w/ the VDC.
Old May 26, 2006 | 05:40 AM
IslandZavage
Is you car lowered? How much?
Old May 26, 2006 | 07:11 AM
jcs4's Avatar
jcs4
I was rubbing on 1-1/2 drop in the rears on big bumps (w/ a 22mm offset). My fenders are not rolled. On stock suspension there was no rubbing at all.
Old May 26, 2006 | 07:43 AM
noodleman's Avatar
noodleman
if you get 8.5 and 9.5 widths, 245 and 275 size would be perfect (it's the width combos that Nismo uses on the LMGT4s).
I have the same set up. I can't comment on the rubbing issue, as my offsets aren't as aggressive as yours.
Old May 26, 2006 | 12:05 PM
IslandZavage
you guys have any pix to show, so i could get a better idea of what they'll look like?
Obadabot
Jun 18, 2023 11:31 PM
