Spacers?
Originally Posted by kpiskin
I personally wouldn't buy "one size fits all" spacers. You run a higher risk of your wheel coming off.
Those are fine as long as your wheels are lug centric.
Originally Posted by moorefire
There is absolutely no reason why those would cause your wheel to fall off...
If he is using the Stock Lugs 8mm will not leave enough threads for the lug nuts to engage. Also, Never go with a spacer that is not Hub-Centric, the small ammount of mis-alighnment between the wheel, spacer and hub will cause premature failure.
Originally Posted by JPsZ
would you need longer studs for a 5mm spacer?
Performance Nissan
Performance Nissan
NISMO Hub Bolts:
50mm are around 10mm longer then stock...
60mm are around 20mm longer then stock...
http://www.mynismo.com/products/?id=2574
Originally Posted by 1nate7
Ichiba, can you PM me a price for wheels studs long enough to accomodate a 15mm spacer? I already have the spacers, just need 10 longer studs.
If you need some ichiba products, Jason@performance would help you alot.
FromGtoZ
Sep 20, 2015 03:41 PM
15mm all around. $210 shipped
