inner tire wear
on
inner tire wear
ok im not no suspension guru so i need some help.
i have a 2003 350z, and i got a flat so i put my doughnut on my front left tire. i noticed while i lifted my car that the inside of my wheels were really worn out. I was told by fixing the camber i would fix this problem because the wheel is actually sitting stock on the inside more than the outsides. What would i need to buy to fix this problem on my car. I'm getting new tires and rims soon so i dont want this problem to keep happenning.
thanks in advance
thanks in advance
Guest
Posts: n/a
This is one of the most common problems on the early model Z's. Its called feathering and there is probably about 200 threads on here about it. Dealer should take care of it for free if you have an 03 and are within the right amount of miles on the car.
inner tire wear and feathering are 2 seperate issues. and although nissan did extend the alignment warranty on 03 Z's, all of those Z's should be well past that period. the best thing is to get an alignment and replace your tires with a better wear rating. do a search and you should find tons...
Originally Posted by davidv
Besides these 195 posts...
https://my350z.com/forum/search.php?searchid=1561080
...this is the first that I have heard about it.
Sorry - no matches. Please try some different terms.
Searches are NOT persistant, they are cached and go away after a short time.
on
hey davidv if u wanna answer, answer, dont come here acting all smart behind your computer screen. i know of the problem i just couldnt find the parts that will fix this cause i know you can buy some suspension parts that will correct this problem.
You probably don't need suspension parts to fix the problem. It all depends on what the cause is. If it's purely an alignment issue, get it realigned and get new tires and you'll be okay.
If it's the feathering problem, take it to a dealer ASAP. They will realign and should replace the front tires. Assuming the TSB is still in effect. There was a time limit on getting that done.
Keep in mind that due to the amount of camber in most all sports cars, the tires tend to wear quickly, especially on the inner edges. You didn't mention how much mileage or if it was front/rear tires.
Performance Nissan
Performance Nissan
on
see this thread... helps on the front with stock set up...
https://my350z.com/forum/brakes-and-suspension-diy/137762-how-to-rotate-staggered-directional-tires.html
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
