18X9.5 +20 w/ a 245 or 255 tire??
Old Jul 15, 2006 | 07:40 AM
first350's Avatar
first350
Default 18X9.5 +20 w/ a 245 or 255 tire??
Can I run a 18X9.5 +20 rim with either a 245(or 255)/35/18 tire?? I don't want to get my fenders flared, rolled or cut - and I don't want the tires to rub.
details:
I just put an order in for Work Emotions (CR Kai):
F: 18X8.5 +20
R: 18X9.5 +20
The tires I was going to get were BFG KDW:
F: 245/35/18
R: 275/35/18
...but the front rims won't be in until next month, while the rears are in stock...
I have an '05 Enthusiast w/ Hotchis springs (lowered about 1").
**I searched for several hours but couldn't find anyone with the same set-up (I found some ppl with the same front rim/tire combo, but no info on if they had springs/coilovers)
thanks!!
-Peter
Old Jul 15, 2006 | 08:10 AM
twenzel's Avatar
twenzel
I would go for 255/35/18 in front, and 265/35/18 in rear.
Old Jul 15, 2006 | 08:35 AM
3FITTTY's Avatar
3FITTTY
im sorry... what is wrong with the normal 245/40 275/40?
Old Jul 15, 2006 | 08:41 AM
first350's Avatar
first350
from what I've read, a 245 can fit a 9.5" rim width - but it's streched.
I just want to know if a 18X9.5 +20 rim with either a 245/35/18 or 255/35/18 tire and a 1" drop will rub. IS anyone running a similar set-up and can say if this rubs???
(The roads around here are nice and there's not too many potholes, so I don't mind going with a 35 profile if it'll give me a bit more room for clearance.)
thanks!
Old Jul 15, 2006 | 11:08 AM
1nate7's Avatar
1nate7
thanks!
245/40 and 275/40 will fit fine with no rubbing. Those offets aren't that aggressive in those widths, you won't have any issues.
Old Jul 15, 2006 | 11:19 AM
dkmesa350z's Avatar
dkmesa350z
245 front 275 rear
Old Jul 17, 2006 | 06:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
245 is going to look ridiculous on a 9.5 inch wheel
255 is your best bet
if you are lowered, you WILL be rolling your rear fenders if you run KDW's
PLAYDIRTY
Oct 12, 2015 07:45 AM
