What Toyo T1Rs are "NOT" supposed to look like
Well leaving the driveway and I see a tire streak going down the driveway, get out and tire is flat. Took them off and this . . .
any thoughts ? I think the shop that put in my suspension F*ed up cause that looks horrible
T
T
alignment did that to mine. i lowered my car and like i always do i procrastinated my alignment for 5 months.. next thing i know my so called new tires were gone. wires popping out and all.
deffinately an alignment issue, uneven wear. camber is off. lowered car? suprised you didnt hear it coming, same problem as tire feathering just lots more severe. were they really loud?
Funny thing thats on 6000miles with one alignment when the new wheels and tires went on and another at 3000 so Im thinking when the suspension was put on the toe was way off, so in other words they probably lied cause they said it was almost perfect to Nissan Spec BS
T
T
Looks pretty normal to me for a drop of 1"+. This is why there are hundreds of threads on camber kits and uneven tire wear. Rotate them side to side before they get to that point and you can get 2x the life out of them. Also, make sure you get a print out of your alignment specs next time so you know exactly what you are dealing with. You could have as much as -2.5 degrees of camber.
Originally Posted by TayTaythatsme04
lowered on eibachs but I wont think it would have that much of a effect
T
T
Wrong...this is probably the biggest contributor. You must've had some big camber, which, unless you got camber arms, cannot be adjusted back to spec with your eibach 1" drop.
You gotta pay more attention and do the tire / wheel flip-rotation thing (sticky by Jason@perf)
Loud ? no not really
And yes lowered on eibachs but I wont think it would have that much of a effect
T
T
