Work XD9 on a CS Z :-D ***PICS***
Old Aug 1, 2006 | 02:59 PM
plumpzz's Avatar
plumpzz
Default Work XD9 on a CS Z :-D ***PICS***
Im not lowered yet. I need to find a nice place to install my springs!
The shop told me since my rear sticks out below the fender a little i wont pass inspection :-D Oh well. Ill worry about that in September of 09 lol. I included some weird angles to show how flush it is w/ the fender and the camber on the bottom.
I almost spun out while leaving cause the tires were slick. I didnt think they'd be THAT slick. I gave the normal amount of throttle i normally give lol.
The tires are
Kuhmo ASX 245/40/18F 275/40/18R On Work XD9
Thanks Z1 in New york!
mommy is checkin out the dubs in one of the pics haha. She says hi Z losers.
PLUG: My stock 17s are for sale! I've gotten several PMs but no bites! PM me.
Attached Thumbnails Work XD9 on a CS Z :-D  ***PICS***-how-flush.jpg   Work XD9 on a CS Z :-D  ***PICS***-jdm-squared.jpg   Work XD9 on a CS Z :-D  ***PICS***-mad-jdm-yo.jpg   Work XD9 on a CS Z :-D  ***PICS***-mommy-.jpg   Work XD9 on a CS Z :-D  ***PICS***-3-4-angle.jpg
Old Aug 1, 2006 | 07:36 PM
masterj26's Avatar
masterj26
nice got my rims today. Tires will be here by the end of the week, i went with 255/35 and 285/35 i don't know if im going to keep those tires or send them back and get 245/40 and 275/40, either way should have them on the car next week.
Old Aug 1, 2006 | 08:03 PM
plumpzz's Avatar
plumpzz
Stick w/ the ones u have. the 40 series gives too much buldge. However, they rid better than stock...ALOT better. The tires are mad quiet lol.
Next time i get tires, im going w/ 255/35 and 285/35
However, im also lacking a drop, which makes the big profile even worse.
Old Aug 1, 2006 | 08:37 PM
Pac Man's Avatar
Pac Man
Bro, the bronze looks good!!! Post some more pics if you can. BTW, I've got a CS and some matte silver metal XD9's. I guess I should get off my lazy *** and order my tires; I've had my wheels for a couple weeks already. I am thinking of maybe getting the Falken 452's - 245/40 & 275/40.
Old Aug 1, 2006 | 08:39 PM
plumpzz's Avatar
plumpzz
Like i said, you should get 35 series :-D
If you got the lowest offset though, it will probably rub. I sit 100% flush on the fender in the rear. You'd need about 1/2 degree of camber to be flush if you're lowered
Old Aug 1, 2006 | 08:42 PM
masterj26's Avatar
masterj26
Pacman i got the same rims going on my LS, should have them on the car by early next week i got the falken 452 but in the 35 profile as plumpzz is suggesting. I am keeping my fingers crossed that i don't rub
Old Aug 1, 2006 | 08:43 PM
plumpzz's Avatar
plumpzz
if they rub, just roll the fenders. I doubt your fronts will rub but the rears will probably if you're lowered more than an inch and in factory specs for alignment
Old Aug 1, 2006 | 08:45 PM
masterj26's Avatar
masterj26
im lowered 1.2" in the rear and not currently in factory specs soo we will see
Old Aug 1, 2006 | 08:49 PM
plumpzz's Avatar
plumpzz
when i used the good old finger measure trick, i was able to fit 4 fat fingers. If you're lowered by 1.2' and using a 35 series tire, which should be slightly less than 40 profile, then you MIGHT be fine, but definatley within specs to have it rolled and be perfeclty fine. Good looks!
Old Aug 1, 2006 | 09:29 PM
L337350's Avatar
L337350
those look nice.. same rims as me i can almost fit one finger in the rear fender but the tire is inside due to camber.. i still had rubbing issues though
Old Aug 2, 2006 | 11:37 AM
A Spec Products's Avatar
A Spec Products
not sure if this pic has been posted yet, but xd9s on a 350z:
its a rendering but a damn good one at that
Old Aug 2, 2006 | 07:46 PM
plumpzz's Avatar
plumpzz
Anyone know the best way to get rid of the 4 X 4 look? Im looking into just lowering springs. Im sure that wont do it... The tires/wheels are flush w/ the top fender so i know its possible..
Ibasically want it to look like ^ that, but with about an inch more clearance front and 1/2 more in the rear
Old Aug 2, 2006 | 08:06 PM
Zreign's Avatar
Zreign
A full coilover suspension will allow you to drop your car lower than with just springs alone. this will adequately remove the "4x4" look.
Old Aug 2, 2006 | 08:09 PM
plumpzz's Avatar
plumpzz
The problem is i can't be too low or i wont be able to get up my driveway. Its about a30 degree slope driveway
Old Aug 2, 2006 | 09:09 PM
Frostydc4's Avatar
Frostydc4
That looks sick. Did you weigh them? Also what offset did you get? Just lower it 1" and it will look perfect.
Old Aug 2, 2006 | 11:30 PM
plumpzz's Avatar
plumpzz
Yeah i did weigh them. I used a bathroom scale but they both came to 21 lbs ish. The tires weren't bad either. They were at 26 lbs. The stock setup weighs about 20lbs more i think
Old Aug 3, 2006 | 10:18 AM
A Spec Products
Aww cmon man
From the pics of your driveway that is cake man
Just gotta practice your angle skills pulling into the driveway
Old Aug 3, 2006 | 11:07 AM
L337350's Avatar
L337350
Originally Posted by A Spec Products
Aww cmon man
hey logan just wanna say thanks again for the help w/ the wheels i'll hit you up if i need anything else
Old Aug 3, 2006 | 12:00 PM
A Spec Products
yeah if youre ever in the area stop by
i want to peep it in person
Old Aug 3, 2006 | 02:18 PM
plumpzz's Avatar
plumpzz
Aww cmon man
:-D i know the angle skills, from the pics, ur right it doesnt look bad at all. What kind of springs would make my car look good w/o the 4X4 look
