How important is that M brace under the carriage?
Old Aug 2, 2006 | 09:02 PM
plumpzz's Avatar
plumpzz
Default How important is that M brace under the carriage?
How important is that M brace under the carriage? Its hitting my exhaust EVER so slightly. Other than covering that area w silicone, if i remove it, will it be bad? I dont autocross...or race..just sometimes take turns hard
Old Aug 2, 2006 | 09:28 PM
350Zteve's Avatar
350Zteve
Nissan would not add weight and cost to a car if it wasn't necessary. Get yourself some header wrap and cover the exhaust where it passes over the brace. Better yet, loosen up your exhaust and position it better before you tighten it down
Old Aug 2, 2006 | 10:39 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
you can add some shims / washers between the brace the body to make some more room...
Old Aug 2, 2006 | 11:28 PM
plumpzz's Avatar
plumpzz
The positioning idea wont work, i've tried. The exhaust uses clamps and one just wont tighten. Im going to go pick up a new clamp and if that doesnt work, i'll put washers under the brace. That will DEFINATLEY solve the problem. Thanks again jason. PS- my nuts and bolts are coming in tomarow lol
Old Aug 2, 2006 | 11:29 PM
GFrnk69's Avatar
GFrnk69
it's pretty useless, they took it out when i got my exhaust installed and havent noticed/felt any difference
Old Aug 2, 2006 | 11:32 PM
plumpzz's Avatar
plumpzz
The only thing i can see it preventing is frame bending. However, its position (in the center) makes me think that area gets very little torque anyway, and is ment more as a protector for the drive shaft
Old Aug 3, 2006 | 10:20 AM
Art Vandaleigh's Avatar
Art Vandaleigh
Putting washers between the brace and body will help exhaust clearance. I had to put about 3-4 washers on each bolt when i ran crawford cat/nismo exhaust setup.
Old Aug 8, 2006 | 12:10 PM
plumpzz's Avatar
plumpzz
Turned out the clamp was toast. I bought a new clamp and it fixed the problem. I put in spacers just incase. No more rubbing. I had installed and uninstalled the exhaust about 3 or 4 times and the band clamp just wouldnt torque down after being over used and stretched. The new band clamp is tight as a womans.. :-D
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
wayneside
South East
Sep 23, 2015 02:38 AM
