Question about tire and wheel spacer stuff.
Old Aug 9, 2006 | 08:33 PM
aleok's Avatar
aleok
Default Question about tire and wheel spacer stuff.
i'm getting the M45 rims, for my g35 coupe, which have a 50 mm offset. i will need some pretty huge wheel spacers, just for them to fit. i'm currently lowered on 350z s-techs, and plan on lowering a LOT more with coilovers, like 2 more inches. i'm using the oem 19" tires, 225/40/19 and 245/40/19.
the question is:
whats the largest wheel spacer i can get, but when i'm lowered not have the tire hit my fenders. (assuming the camber is in OEM specs). fenders rolled and not rolled...
Old Aug 10, 2006 | 03:27 AM
aleok's Avatar
aleok
bump
Old Aug 10, 2006 | 03:34 AM
baileyrx's Avatar
baileyrx
the easist way is to put the rim on the car & measure the distance from the outer edge of the rim/tire to the inner fender. You can get spacers in almost any size from 5mm up to 3 inches!
Old Aug 10, 2006 | 03:43 AM
sq40's Avatar
sq40
My "Guess" is a 25mm Spacer will fit your application, but you should do as Bailey suggests above.
Old Aug 10, 2006 | 03:27 PM
aleok's Avatar
aleok
i can't really do what bailey suggested because i do'nt have tires mounted on the rims. i'm going to be using the oem tires i'm useing now. i tried mounting the rim, and messuring the height of the 40series tires, but i can't lower the car to get sitting right, so all my measurement didn't make sense.
DarkCreep
Oct 17, 2015 11:50 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
rizzla
Sep 29, 2015 03:58 PM
