PSI on stock tires
Old Feb 27, 2003 | 04:37 PM
Encore's Avatar
Encore
Default PSI on stock tires
What psi are you guys running? Im running 35psi in the front, and 38psi in the rear. I havent had a chance to play with it, and was wondering what you guys had came up with.
Old Feb 27, 2003 | 04:44 PM
JonsilvZ's Avatar
JonsilvZ
My tires are 34psi(front and back). Why do you have more psi in the rear? You know there is a little more lbs in the front? The Zs ride is hard no need to make it harder.
Old Feb 27, 2003 | 05:04 PM
Encore's Avatar
Encore
The reason Im running mine like that is because its my first attempt of finding the right psi. Just trying it out.
Old Mar 28, 2003 | 08:09 AM
Welsh 350Z N's Avatar
Welsh 350Z N
37 fronts 35 rears at speed
Old Mar 28, 2003 | 08:53 AM
Audito350Z's Avatar
Audito350Z
I'm pretty close to Welsh.... 34F/36R at the track. After a 25 minute run session the fronts will get up to about 41-42 and the rears up to about 40-41.
Usually 35 all around for the street.
PeteH
Old Mar 28, 2003 | 08:59 AM
Welsh 350Z N
You're right man. The main aim should be an accurate 35:35 on cold tires with a good digi gauge. Fronts will get up to 40'ish and rears up to 38'ish at speed in my experience.
sales@czp
Sep 23, 2019 03:30 PM
