Need quick help on offset
Old Aug 17, 2006 | 04:14 PM
josephchihweilu's Avatar
josephchihweilu
Default Need quick help on offset
Im about to buy a set of rims off another member and the front wheels are 9.5 inches wide with a +15 mm offset. Is this offset doable? I don't want to run into any camber issues. Thanks in advance.
Old Aug 17, 2006 | 07:11 PM
350zedddy's Avatar
350zedddy
join my club LOL. one thing for sure is you wont be running 275s in the rear . Probably have to roll the fenders in the rear with 245s. HOpe that helps
Old Aug 17, 2006 | 08:00 PM
josephchihweilu
so are u saying that 9.5 with a +15 offset will fit or no?
Old Aug 17, 2006 | 08:38 PM
bamyi's Avatar
bamyi
I have 9.5 and I run 275 in the rear no problem.
Old Aug 17, 2006 | 11:30 PM
josephchihweilu
oh my bad, i meant the front. 9.5 with a +15 offset in the front. I'm worried about whether or not it will stick out from the fender
Old Aug 18, 2006 | 12:10 AM
bamyi's Avatar
bamyi
actually me bad, you did mentioned front in the orginal post.
9.5 will fit but I don't know if it will stick out with those offsets. Here's a calculation tool.
http://marksink.com/tire_wheel_offset/offset.html
Old Aug 18, 2006 | 12:35 AM
josephchihweilu
thanks for the help!
looking for anyone whos running more aggressive offset than 15...any issues? camber, rubbing? i did a search and found someone running 9.5 with +17 offset, anyone think 15 is pushing the limits too much?
Old Aug 18, 2006 | 03:54 AM
Mathys's Avatar
Mathys
Does the member you're buying the wheels from have a 350z? Just ask him then.
I think +15 is on the edge, like +17, but will work.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
