Reccomended Tire Widths for Stock Rims
Old Aug 31, 2006 | 11:57 PM
ChadS's Avatar
ChadS
Default Reccomended Tire Widths for Stock Rims
Hey all.
I've got a 2006 Nissan 350 Touring and have decided to replace all four tires after my back OEM tire blew out with Goodyear Eagle F1s and figured I might as well play with the tire widths etc while I was at it. I know very little about cars and was hoping someone could recommend some combinations that will fit on the OEM rims which I am not replacing and say what the pros and cons are of various combinations. For example, will changing the widths somehow change the accuracy of my odometer etc? I would think this is only true with wheels of different diamter...
Also, I've heard talk about no-touch tire mounting or something like that? Is this a really such a big deal that I should be sure to find a place that mounts this way?
Lastly, after I put my new tires on I'm going to have 3 perfectly good oem tires with about 500 miles on them. Is there somewhere to sell things like this? Can I do anything with them because throwing them out seems like a shame but I don't really have anywhere to put them.
Much Thanks.
- Chad
Old Sep 1, 2006 | 12:02 AM
sugarspunZ's Avatar
sugarspunZ
your wheels are 18's right?
Old Sep 1, 2006 | 12:03 AM
ChadS's Avatar
ChadS
Yep.
Old Sep 1, 2006 | 12:04 AM
sugarspunZ's Avatar
sugarspunZ
if you have 18's i would go with 245/40/18 fronts and 255/40/18 rears
Old Sep 1, 2006 | 12:15 AM
ChadS's Avatar
ChadS
Thanks for the response.
Any idea what that will do for my car? I assume better traction since wider wheels?
- Chad
Old Sep 1, 2006 | 03:05 AM
Q45tech's Avatar
Q45tech
I know very little about cars.......... assume better traction since wider wheels?
The contact patch AREA always stays the same regardless of width......pure function of weight on tires and inflation pressure. The shape does change, however----wider just narrower lengthwise.
Lower sidewall height just changes the sidewall stiffness.
Traction [dry] is a function of tread softness the faster the tires wear the better the traction between the road surface molecules and the rubber molecules.
Wider is not always better especially when friction drops due to temperature or moisture.
Old Sep 1, 2006 | 01:34 PM
ChadS's Avatar
ChadS
Ok. So then can someone explain to me the point of having wider wheels? Is it that it looks better? The lower profile 245/40 and 255/40 wont make the car look weird by making the space at the wheels larger since I haven't lowered my car will it? I've heard that it's pretty large and open to begin w/...
Chad
Old Sep 1, 2006 | 01:46 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Chad
When you're cornering, you have lateral g-force. Extra weight goes to the side of the car. If you have skinny tires, not as much lateral rubber to provide traction.
The tires that came on my 05 touring were 225/45/18 and 245/45/18 ... I wouldn't get much wider tires unless you have much wider wheels.
Old Sep 3, 2006 | 04:52 PM
ChadS's Avatar
ChadS
Wired: Thanks for the info.
Any opinions on whether the 245/40 front 255/40 back on OEM rims will make my Z look weird since I haven't lowered it or done any mods to it at all?
Appreciate it.
- Chad
Old Sep 3, 2006 | 06:11 PM
Kolia's Avatar
Kolia
It will be great like that ;-)
I run 235/40R18 and 255/40R18. But at that point, it's pretty much a question of size availlability.
Old Sep 3, 2006 | 07:28 PM
ChadS's Avatar
ChadS
Kolia, thanks for the feedback. I'll do it...
- Chad
Old Sep 3, 2006 | 08:55 PM
I recommend the OEM width plus 20mm. No more.
Old Sep 3, 2006 | 09:14 PM
- Chad
Ripken Stadium, Aberdeen, MD. 06/17/06
As Q45tech and Wired 24/7 mentioned, the outside tires hold the car to the pavement. If you can keep more rubber on the road, the better. BTW 295mm of crummy rubber is no better than 235mm of quality rubber. And adding 10, 20 or 30mm will not turn a novice into a pro.
Old Sep 3, 2006 | 10:41 PM
UR NZWY's Avatar
UR NZWY
Not to thread-jack, but Im going to be buying some new tires for my stock 17's on thursday. What tires sizes recommended for those?
Old Sep 4, 2006 | 03:18 PM
Kolia's Avatar
Kolia
Originally Posted by RadioManJ350Z33
FRONT:
Your speedomoter is reading 2.2% higher than you are actually traveling.
So when your speedo says... "80mph" it is really... 78.24mph. so for every 100 miles, you are actually putting 102.2miles on the car, b/c your 236/40 size is smaller than your stock size, even though the width is wider. That's an extra 330miles for every 15,000 miles of driving.
I know; lame... but true.
A 245/40/18 on the front reads 1% too fast, and would add an extra mile for every hundred miles; an extra 150miles for every 15thousand miles.
REAR:
You rear is reading 2.4% too fast. A 265/40/18 would read 1.3% too fast.
So the propper PLUS size on stock rims are...
245/40/18 front
265/40/18 rear
Anything bigger thatn these previously mentioned sizes will push the side wall over the rim, and cause the tire bead to not seat propperly, and drastically reduce lateral handling; aka... BULDGing.
FRONT: 245/40/18...
Kumho ECSTA MX - $148
Avon Tech M500 - $138
BFGoodrich g-Force Sport - $130
BFGoodrich g-Force T/A KDW - $159
BFGoodrich g-Force T/A KDW 2 - $171
Bridgestone Potenza RE750 - $170
Dunlop Direzza DZ101 - $131
Fuzion ZRi - $127
General Exclaim UHP - $110
Kumho ECSTA SPT - $123
Kumho ECSTA Supra 712 - $115
Sumitomo HTR Z II - $100
Yokohama AVS ES100 - $139
Continental ContiExtremeContact - $159
Kumho ECSTA ASX - $116
AND MANY MANY MORE!!!
REAR: 265/40/18
CHA CHING $$$!!!
You obviously but a lot of effort in there.
A new question for you. Since it's the VDC/TCS/ABS system that sends the speed signal, which wheel is the one actually read? Or is it an average of all four?
Also, not all tires of a given size are really the same size.
And finally, the odometer correction on my car is the least of my worries. All the beter if I'm travel slower than my indicated speed. Less speeding tickets. I'm much more interrested in the car's balance and performance.
Old Sep 4, 2006 | 05:55 PM
lowrider's Avatar
lowrider
delete
Old Sep 4, 2006 | 05:59 PM
lowrider's Avatar
lowrider
8" wide wheel... 225 minimum - 245 maximum
8.5" wide wheel.... 235 minimum - 255 maximum
9" wide wheel... 245 minimum - 265 maximum
9.5" wide wheel... 255 mimimum - 275 maximum
10" wide wheel... 265 minimum - 285 maximum
10.5" wide wheel... 275 minimum - 295 maximum
11" wide wheel... 285 minimum - 305 maximum
Front - 245/40/18
Rear - 255/45/18 or 265/40/18
- Any bigger the side wall will bulge and lower lateral performace, also the tire bead will not seat properly and cuasse blow out.
+1 - 245/40/1/ front 265/40/18 rear is the largest size you should run on the 8" - 8.5" wheels on the '06.
Lou
