Quick question: What are these for (see pic)
Old Sep 3, 2006 | 11:26 AM
l33r0y's Avatar
l33r0y
Question Quick question: What are these for (see pic)
Received a set of wheels and tyres from WheelAutohaus (thanks again Charles for a very professional service )
I'll be fitting these tomorrow if the weather holds, but I'm wondering what the 4 black plastic rings supplied, what are they for exactly?
My guess would be something to do with the inner hub area, but under what circumstances would they be needed for my stock 350Z? i.e. are they mandatory or just for a particular situation?
The wheels are:
Lexion 203 (RAYS)
19x8.5 with 245x35x19 Toyo T1-R
19x10 with 275x35x19 Toyo T1-R
Thanks for any help
(Lug nut showed for scale)
Old Sep 3, 2006 | 11:29 AM
Eazzy's Avatar
Eazzy
They are called eccentric rings or something like that and fit into the hub hole on the inside of your wheel ---They help center it on the hub
Old Sep 3, 2006 | 11:31 AM
solidsnake's Avatar
solidsnake
HUBcentric rings.
l33r0y's Avatar
l33r0y
Are they mandatory or should I just slap them on and mount on my stock setup?
Cheers
solidsnake's Avatar
solidsnake
Old Sep 3, 2006 | 11:32 AM
solidsnake's Avatar
solidsnake
Cheers
Not mandatory but can only HELP you. Just use them. or send them to me. haha!
Eazzy's Avatar
Eazzy
Originally Posted by solidsnake
HUBcentric rings.
Old Sep 3, 2006 | 11:34 AM
Eazzy's Avatar
Eazzy
Dont make me get out of this chair !!!!!!
Old Sep 3, 2006 | 11:35 AM
l33r0y's Avatar
l33r0y
Thanks again you lot
Hopefully the weather will hold out for a few months here in the UK before I'll need to put the winter wheels back on - I want to enjoy the new blingage
Old Sep 3, 2006 | 11:36 AM
plumpzz's Avatar
plumpzz
They help to make sure the wheel is centered on the hub so when it spins, its balanced.
Old Sep 3, 2006 | 11:37 AM
Eazzy's Avatar
Eazzy
Bling away !!!!! Trade u weather ----100 degrees everyday for the last 10 months. Well maybe I exagerate
Old Sep 3, 2006 | 12:16 PM
1nate7's Avatar
1nate7
Chances are your Rays are 73mm bore and the hub is a 66mm. Those hubcentric rings fit into the Rays to center them on the hub. If you take off the Rays, make sure the rings stay in the wheels. The stock wheels have a 66mm bore to fit the hub already, so if the ring stays on it will cause problems.
Old Sep 3, 2006 | 01:22 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you should use them..makes installing the wheels and torquing your lugs a no brainer. As mentioned they center the wheel on the hub
Old Sep 3, 2006 | 04:45 PM
l33r0y's Avatar
l33r0y
Thanks again
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
