Buying rims/tires on tirerack have question... need help
Old Sep 3, 2006 | 03:45 PM
mndthegap1's Avatar
mndthegap1
Default Buying rims/tires on tirerack have question... need help
okay so im going to buy Motegi Track touge rims
18x9 in the front +25mm offset
18x10 in the rear +30mm offset
question is tirerack says to get 225/45-18 front and 245/45-18 rear for tires.
is this correct ? or should i do 245 in the front and 275 in the rear ?
also i want the rims to sit flush with the fenders i have eibach pro kit with 1.2 inch drop all around...
thanks in advance link isnt working but here is the actual info :
Finish Shown: Black w/Mach Lip
Other Available Finishes:
Anthracite w/Mach Lip
Chrome Plated
Size Selected: 18x9Front
Price: $234 (each)
Estimated Availability: In Stock
Recommended Tire Size: 225/45-18
Wheel Offset: +25mm
** Lightweight: 25.5 lbs. **
Size Selected: 18x10 Rear
Price: $243 (each)
Recommended Tire Size: 245/45-18
Wheel Offset: +30mm
** Lightweight: 28.0 lbs. **
Additional Specs
Bolt Pattern: 5-114
Finish Warranty: 1 YEAR
Country of Origin: CHINA
Construction Type: 1 PC CAST
Old Sep 3, 2006 | 03:49 PM
masterj26's Avatar
masterj26
most go with 245/40/18f 275/40/18r
Old Sep 3, 2006 | 04:39 PM
syk69's Avatar
syk69
those are the same rims im gettin for mine. though im going with 245/40/18 and 285/35/18 and tire rack isnt the cheapest place to get them. try going to http://www.wheelsfortuners.com
i think it would be like $797 shipped way cheaper than tirerack. im gonna get mine with the toyo proxes t1r's too. hopefully it will look nice.
Old Sep 3, 2006 | 04:45 PM
masterj26's Avatar
masterj26
i went with 245/40/18 and 285/35/18 falken fk452. Check with Luke of discount tire for tire prices
Old Sep 3, 2006 | 04:47 PM
syk69's Avatar
syk69
hey masterj, what do you think of your falken's? i noticed they are cheaper than the toyos. im not to familiar with that brand.
Old Sep 3, 2006 | 05:29 PM
masterj26's Avatar
masterj26
honestly i am very happy with them. they have good wet and dry traction.
Old Sep 3, 2006 | 08:44 PM
InSaNeZ's Avatar
InSaNeZ
I would actually go with a 255 in the front.
Old Sep 3, 2006 | 10:46 PM
The TireRack does a good job with recommended offsets. But as far as tire sizes, I haven't the faintest idea how they arrive at such weird sizes.
Old Sep 4, 2006 | 10:13 AM
mndthegap1's Avatar
mndthegap1
thanks everyone for the responces.
well they are ordered 1554 for rims/tires mounted, balanced and shipped 2nd day.
went with 18x9 front with 245/40/18 front
and 18x10 with 275/40/18 rear
came with lugs and everything...
ill post pics once they are on.
Old Sep 4, 2006 | 10:28 AM
Brick-Z's Avatar
Brick-Z
225?????Are those motorcyle tires????
Go with the 245F-285R
Old Sep 10, 2006 | 06:31 AM
Gerry's Avatar
Gerry
Seems like a lot of wheel and tire sites are conservative as far as tire to rim size. Ive seen some sites that reccomend a 225 tire on a 9.5". I went with Tire Racks reccomendation on tires. They did good on the rear I went with 18x10.5 with a 275/40 but the front I went with 18x9 and the 225/45 and it is stretched. Its not terrible but the rim protecter isnt doing much. Next time I get tires Ill go with 245 in front.
Old Sep 12, 2006 | 06:49 PM
bonusfrag's Avatar
bonusfrag
With a configuration of 245/40/18f and 275/40/18r, is that going to set the TCS off all the time, or is that OK? Sorry, I'm a noob.
Old Sep 12, 2006 | 06:56 PM
Nexx's Avatar
Nexx
nope, you're good.
Old Sep 12, 2006 | 06:58 PM
XZLR8NZ's Avatar
XZLR8NZ
how wide can i go with the stock 17's right now i have 235/40/17 in rears and 225/50/17 in the front?????
Old Sep 12, 2006 | 07:06 PM
dubbzdiggler's Avatar
dubbzdiggler
The reason the tire rack knows the offsets and sizes is because they do the research...they actually have all of the most high tech equipment to measure out fitments and what not. The sizes are actually a pretty exact science...the Z is set up to have a rear tire that is about an inch or so give or take taller than the front tire. If you go with a 285/35R18 then it's not quite the right fitment, plus with a 245, the correct and most common stagger is 275 rear and with a 285 rear, you want 255's in the front. Listen to what the Tire Rack has to say, they know what they are talking about. Plus, if something is damaged, Tire Rack will take it right back unlike some of the horror stories I've read on here where companies ignored customer complaints and avoided problems...and why does everyone want cheap tires, you're car works better with good tires. You get what you pay for.
Justin100
Nov 25, 2021 06:26 AM
Alexreyes
Sep 30, 2015 11:30 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
