TPMS Help!!
Old Sep 4, 2006 | 11:27 PM
ESPO 774's Avatar
ESPO 774
Default TPMS Help!!
I decided to plug one of my tires that had a nail in it today. I removed the wheel, and plugged it. I put the wheel back on and everything was fine, until later in the day my TPS light came on. My pressure is 39 all around, do I have to reset the system or something? anybody have any idea?
Old Sep 5, 2006 | 03:41 AM
DavesZ#3's Avatar
DavesZ#3
There shouldn't need to be anything done as far as a reset is concerned.. Did the sensors read 39 or did you use a gauge to measure it? The alarm doesn't normally go off unless the pressure is read at 28 or below.
Old Sep 5, 2006 | 02:04 PM
Gerry's Avatar
Gerry
Could the nail or plug have hit the TPMS sensor?
Old Sep 5, 2006 | 02:08 PM
VO...'s Avatar
VO...
Administrator
where is the TPS mounted? Maybe it was damaged by the weight of the vehicle when the tire went flat.
Old Sep 5, 2006 | 02:31 PM
Gerry's Avatar
Gerry
TPS sensor is attached to the valve where you service the tire. Basically on the inside of the rim attached to the outer valve. I think that even if your tire should go flat the sensor should not hit the ground.
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
tschangrx7
Nov 26, 2006 09:39 PM
