Rota P45R's owners: question
Are the rear wheels' center openings for the hubs deep enough to fit correctly onto the hub when bolted on or is there a little gap?
Thanks
Thanks
All aftermarket wheels are typically universal bore (~73.1) so you'll need a hubcentric ring if you are concerned with vibration.
You don't NEED them, but just depends on your situation. As long as you mount and torque wheels properly you are fine.
I'm not too sure what you meant by "deep" though.
