Tire pressure - wide wheels/tires
Old Sep 15, 2006 | 05:58 AM
Shahrum's Avatar
Shahrum
Default Tire pressure - wide wheels/tires
Hey all,
I just got new tires put on my 18" Kazera KZ-A's. Just wanted to confirm what tire pressure I should use since the car came with the 17's and the sticker inside the console lists 35psi for the 17" wheels -- wasn't sure if this applies to my new wheels as well.
Front:
Kazera KZ-A 18x8.5
Bridgestone Potenza RE050 Pole Position 245x40
Rear:
Kazera KZ-A 18x9
Bridgestone Potenza RE050 Pole Position 275x40
I usually fill up to 36-37 just to deal with high-speed/highway driving, but when I took the car in for an alignment yesterday at a Nissan dealership I got the car back with 40psi all around. Figured I'd ask you all Z owners before holding my breath on a call back from the dealership.
Old Sep 15, 2006 | 06:16 AM
Shahrum's Avatar
Shahrum
In case this helps... they are:
93Y - front
99Y - rear
Old Sep 15, 2006 | 06:33 AM
Correct. 35PSI.
Old Sep 15, 2006 | 12:47 PM
Category5's Avatar
Category5
Were you able to normal-mount the TPS monitors for those wheels, or did you have to use the band-method (discussed on this forum)?
Old Sep 15, 2006 | 01:11 PM
Shahrum's Avatar
Shahrum
Thanks. And actually even tho I have an auto. touring, it came with the 17" OEM wheels so there was no TPS. So I didn't have to worry about it with these either.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
