Strut bar
Old Sep 17, 2006 | 09:54 AM
Bday350z's Avatar
Bday350z
Default Strut bar
I need to buy a new strut bar..since my car does not have one..not sure why, so I need some comments on strut bars..which one is best! I'm going to get a 5/16 spacer so keep that in mind.
Also, i really like the looks of the greddy one so pictures of them would be nice too..and comments or complaints about the greddy.
Old Sep 17, 2006 | 10:03 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I went with ARC for the bling factor and plus it is titanium and super light (1.2lbs). That is with a 5/16" Motordyne Plenum spacer installed
Old Sep 17, 2006 | 03:55 PM
Bday350z's Avatar
Bday350z
Would I have to remove my plastic engine cover with that one?
Old Sep 17, 2006 | 07:02 PM
Bday350z's Avatar
Bday350z
Does anyone have the JIC, quick responses would be nice, I will be ordering tomorrow.
Old Sep 18, 2006 | 07:09 AM
davidf's Avatar
davidf
Cusco is not a bad choice. I love the ARC but $$$$$$$$$$$$.
Old Sep 18, 2006 | 07:14 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
I want that ARC Rick where and how much ?
Old Sep 18, 2006 | 08:16 AM
Bday350z's Avatar
Bday350z
The ARC is very expensive its almost $500 compared to most that are around 2-300$
Old Sep 18, 2006 | 08:17 AM
Bday350z's Avatar
Bday350z
But again does anyone have the JIC??
Old Sep 18, 2006 | 08:42 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
No, I just removed mine along with most of the useless engine plastic
Old Sep 18, 2006 | 08:43 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I would suggest going through Performance Nissan or Z1auto.com for this one, but if it is for you personally or someone you know I can get it cheaper
Old Sep 18, 2006 | 09:52 AM
JamMasterW's Avatar
JamMasterW
Exclamation
some pix: https://my350z.com/forum/ride.php?do=view&id=59585
Old Sep 18, 2006 | 10:01 AM
Eazzy's Avatar
Eazzy
With the 5/16 spacer-----Dollars and Cents wise go with a used stock one and have ur local Powder Coat Guy do his thing to it. To others ----I really wouldnt leave it out, Its a STRUT bar, It stiffens the top of the two struts and eliminates the flex u get on hard cornering. Its important to adjust it properly also.
Old Sep 18, 2006 | 10:36 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
for me and my Lemans ....
Old Oct 22, 2006 | 04:16 PM
DanielW's Avatar
DanielW
how do you properly adjust the strut bar?
Old Oct 22, 2006 | 04:37 PM
Eazzy's Avatar
Eazzy
Nuts should be at 20 FtLBs Bolts at 30 FtLBs---Loosen lock nuts and turn center Hex nut CCW looking at it from the front and to the left ( Top of nut turns towards the front )---Turn it till have a .400 - .675 space between bar and upper plenum.
Thats with all stock components. Main thing is u want there to be a load on it
Old Oct 22, 2006 | 06:27 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Cusco
in stock too
http://www.z1auto.com/prodmore.asp?m...ing&prodid=989
Old Oct 22, 2006 | 06:57 PM
Bday350z's Avatar
Bday350z
How would that fit when I can't fit anything over the plenum...
Old Oct 22, 2006 | 07:11 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Has anyone seen a strut bar that will clear the Skunk2 spacer the OP has in his sig?
Chris
Old Oct 23, 2006 | 12:11 AM
Z33Benny's Avatar
Z33Benny
Here was the JIC on my car...
Old Oct 23, 2006 | 05:54 AM
chimmike's Avatar
chimmike
if you haven't removed it, don't screw with it. Especially YOU.
