>>>>>>>Volk Owners Only<<<<<<<<
Old Sep 13, 2009 | 12:06 PM
  #1961
SIR_pierre's Avatar
SIR_pierre
Originally Posted by Jacob350z
unless your have huge tires there is not reason to why you would be rubbing.
i have 10.5 all around with +13 front and -2 in the rear and i dont rub.
im max on stock camber in the rear and have a arms in the front at -2.0 on fronts.
thats sounds insane! pics?
even my 255 in the front rubbs when i park/ turn the wheel to max and my 295 rubbs ALOT when i drift
and the Toyo R888 are a bit wider then street tires
EDIT ,. saw the pics now
Old Sep 13, 2009 | 12:12 PM
  #1962
SIR_pierre's Avatar
SIR_pierre
Originally Posted by sry110
I have 10.5 +22 rears with 285/35/19 toyo's and they rubbed until I got my fenders rolled. Lowered on Hotchkis springs and within OEM camber limits. But I wouldn't say 285/35's are "huge".
im not worried at all about the rear. im just wondering if i could go with a "smaller" offset then +22 to look even more fatass
this was with 285 .. i cant even see the tires!
but the big question is about the front.. im now having 9 instead of 9.5 and im getting Seibon 10mm wider fenders... so what offset should i go with to get that wide look?
and perhaps i should have another offset then +22 in the rear?
Old Sep 13, 2009 | 12:17 PM
  #1963
Jacob350z's Avatar
Jacob350z
you could keep the +22 offset in rear and just add a spacer. fronts i would try to get a lower offset so you wont need to add spacers to the fronts but you might not be able to get a really low offset in the rims you want so you might just need to add spacers so you might want to add a spacer to the front to try and get you around +8 that would get you a wide stance and poke out some.
but tires will make a difference like i said before
Old Sep 13, 2009 | 12:23 PM
  #1964
SIR_pierre's Avatar
SIR_pierre
as i get it they dont have these in stock so they will make what i order anyway. and dont like spacers =)
i just want somethings that fits just fine as they are
and when it comes to tires im 100% on 295 in the rear and 255 or 256 in the front. Toyo R888
Old Sep 13, 2009 | 12:39 PM
  #1965
SIR_pierre's Avatar
SIR_pierre
you have to understand that the width sizes are different on the 18s your getting.
if you had 9.5 fronts then yes +12 would not be bad those would be flush but not really poking out. and the rears would need a spacer.
oh..ok..then i have everything whrong..
so a 19/9.5 +22 and a 18/9.5 +22 both with 265 tires dont look the same on the car???
Old Sep 13, 2009 | 12:44 PM
  #1966
Jacob350z's Avatar
Jacob350z
no those do look the same but you said you were getting a 9 up front not a 9.5.
rim width makes the offsets different
like a 9.5+10 is the same as a 10.5 -2 give or take a few mm.
Old Sep 13, 2009 | 12:53 PM
  #1967
SIR_pierre's Avatar
SIR_pierre
yes exacly and thats my problem. now im getting 9 instead.
så my question is just really, a 9.5 +22 is the same as a 9 + ??
Old Sep 13, 2009 | 01:10 PM
  #1968
nuckinfutz74's Avatar
nuckinfutz74
Can you post a side profile of this car for me?
Old Sep 13, 2009 | 01:12 PM
  #1969
Jacob350z's Avatar
Jacob350z
9.5+22 is similar to a 9+15 give to take a mm
Old Sep 13, 2009 | 01:13 PM
  #1970
SIR_pierre's Avatar
SIR_pierre
here it is from most sides.
http://www.garaget.org/mypage/galler...erre&cat=86887
what where you thinking about ?
Old Sep 13, 2009 | 01:29 PM
  #1971
SIR_pierre's Avatar
SIR_pierre
perfekt answer.. thanks. then ill take +12since im getting the wider fenders. and maybe +18 instead of +22 in the rear
Old Sep 13, 2009 | 04:07 PM
  #1972
ZeezCustomz's Avatar
ZeezCustomz
Got my Phantom Black Volks mounted today more pics to follow, the car is in paint right now and almost done. Repainted to satin black, satin red tails too!
Specs on wheels and tires:
Front:
19x9.5/+17 w/ Hankook V12 255/35/19
Rear:
19x10.5/+18 w/ Hankook V12 285/35/19
Stock suspension, no rub either, flush!
&gt;&gt;&gt;&gt;&gt;&gt;&gt;Volk Owners Only&lt;&lt;&lt;&lt;&lt;&lt;&lt;&lt;-sspx0018.jpg
&gt;&gt;&gt;&gt;&gt;&gt;&gt;Volk Owners Only&lt;&lt;&lt;&lt;&lt;&lt;&lt;&lt;-sspx0027-2-.jpg
&gt;&gt;&gt;&gt;&gt;&gt;&gt;Volk Owners Only&lt;&lt;&lt;&lt;&lt;&lt;&lt;&lt;-sspx0026.jpg
Old Sep 13, 2009 | 04:09 PM
  #1973
Waiz's Avatar
Waiz
^Oh WOW.
That looks killer.
Old Sep 13, 2009 | 05:44 PM
  #1974
2k6-z33's Avatar
2k6-z33
Looks great Zeez...
Old Sep 13, 2009 | 07:02 PM
  #1975
st350z's Avatar
st350z
Pics of my Volk GT-C in Gunmetal with Black Lips...
Old Sep 13, 2009 | 08:09 PM
  #1976
stevezcar's Avatar
stevezcar
Here are a couple of pictures of my 07' with my brand new Volk Challenges. I got off work Friday at 6pm. Rushed home and installed them onto the Z. Washed and took her out for these pictures afterwards.
Attached Thumbnails &gt;&gt;&gt;&gt;&gt;&gt;&gt;Volk Owners Only&lt;&lt;&lt;&lt;&lt;&lt;&lt;&lt;-my350zvolk2acvz.jpg   &gt;&gt;&gt;&gt;&gt;&gt;&gt;Volk Owners Only&lt;&lt;&lt;&lt;&lt;&lt;&lt;&lt;-my350zvolk2bcvz.jpg
Old Sep 13, 2009 | 08:10 PM
  #1977
ZeezCustomz
Originally Posted by 2k6-z33
Looks great Zeez...
What do you guys think of the satin black paint?
Old Sep 13, 2009 | 08:51 PM
  #1978
2k6-z33's Avatar
2k6-z33
^Its awesome any full shots?
Old Sep 13, 2009 | 10:22 PM
  #1979
Waiz's Avatar
Waiz
Old Sep 13, 2009 | 11:28 PM
  #1980
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
<3 volks!!!
